standalone s54 engine and DSC retrofitting into a e30
  • Wanganstyle
    • 2828
    #61
    Originally posted by demlotcrew
    Hi,
    He is flashing a custom map which is far more suited for the E30 chassis and which surpasses the M track mode available on the CSL.
    DSC units are very cheap here in the UK. You can get a complete working setup with connectors etc for around £200.
    If fitting SMG in to the E30 at the same time as the S54 then DSC is essential.
    It's worth the effort believe me.
    Andrew
    Shifting with my own leg/arm and modulating the traction with my right foot has worked quite well for decades......
      • 34847
      #62
      you can't do independent wheel braking with your feet though.
      • demlotcrew
        • May 2004
        • 297
        #63
        And probably going rather slow ;)
        Andrew AT E30zone.co.uk | H23-is | S14
        • Wanganstyle
          • 2828
          #64
          of course. unless one is a professional; you would be lying if you think you are fast.
          come see if you can keep up with me at sears point and laguna Seca here and perhaps you will wonder if I'm that slow... i guess you will be busy with traction control and checking the tampons.
          1:50 @laguna Seca stock Dme usa crappy model e36m
          No abs, no traction control, no tampons for those afraid of real driving.
          • demlotcrew
            • May 2004
            • 297
            #65
            This ABS/DSC setup is fitted on an S14 powered non M chassis, using the top of the range hardware, with light weight hard-lines and fittings everywhere!
            The car is equipped with FIA F1 sensors for maximum optimisation, ABS = faster lap times, fact!
            Andrew
            • Wanganstyle
              • 2828
              #66
              Andrew
              Anyone can spend more money. That guy with a turbo nsx sure spent a lot....Air jacks, gt500 body....
              if you can't modulate analog brakes like those have been doing for decades perhaps you need a driving coach. Or perhaps drive a less aggressive car?
              Driving coach would be better use of time than abs.
              Sent from my SAMSUNG-SGH-I337 using Tapatalk
              • demlotcrew
                • May 2004
                • 297
                #67
                LMFAO, this is not traction control, its ABS with brake assist (DSC). All torque control is disabled (ASC).
                Thanks for the offer, but as yet I've not come across an E36 that I cant over take, even with S54's.
                • Wanganstyle
                  • 2828
                  #68
                  Come play stateside. e30's don't compete in nasa gts here: 36 dominates over 46 and 92.
                  Unless your e30 bodyshell has a porsche 911 gt3 under it; those are a different story
                  • demlotcrew
                    • May 2004
                    • 297
                    #69
                    Nothing to do with money, its all to do with proving what works and what doesn't.
                    I guess that F1 drivers need tuition too........
                    • Wanganstyle
                      • 2828
                      #70
                      Yes red bull is doing GREAT this season. All the UK magazines are reporting about their sore looseness at not being competitive.
                      So much for traction control???
                      If you need the dsc to stabilize the car then tampons are packed along the fire suit and hans. ;-)
                      I also race a e30 wheel to wheel endurance; it's rear suspension is shit compared to a 36. We just don't have the budget for a 36; no pro funding here. If one thinks a e30 is honestly faster than you are just fooling yourself; build a 36m or a 46m in the same manner and drive it.
                      • demlotcrew
                        • May 2004
                        • 297
                        #71
                        You said driver tuition, now you're coming back with Red bull not doing 'GREAT' - My point is that even the best drivers cant modulate the brakes, and you've clearly demonstrated your arrogance with nonsensical and insulting replies, come back with a constructed argument and people might take you seriously.
                        As for HANS, this is a great video showing why one is necessary.
                        I wouldn't drive a caged/harnessed car without one!
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #72
                          Traction control can be a very good tool in a high hp car on the street, atleast in a small, light RWD E30 :D
                          I dont want to go full boost at 150mph in a bend on the highway but with TC i now can :) Or now i dare maybe is a better way to speak hehe :)
                          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                          E30 M50 6 spd 764whp @ 24psi.
                          E30 M20 6 spd 675whp.
                          • Wanganstyle
                            • 2828
                            #73
                            Opinion; don't take it personal. If you were racing here in our series with us I'd hand you a beer and make fun of you at the same time!
                            READ:
                            Hans I race with is full carbon; can't race wheel to wheel in Norcal without one;
                            Have you ever raced WHEEL TO WHEEL with contact?
                            IF you have never raced WHEEL TO WHEEL in a regulated series you have nothing to say; end of discussion - passing cars that are not racing you don't count for shit.
                            Seems quite likely that you have never raced wheel to wheel; for sure not in that shiny pretty e30.
                            Much different than just putting in hot laps; the other racers are physically in your way - traction control wont help you pass them as much as actually racing skills / training.
                            red bull had CHEATER traction control; Worked great for them before everything changed this season and no more special cheat; they cant seem to win anymore.
                            Red bull = cheaters to win; straight loosers without the cheating
                            I stated that you must have a package of tampons next to your hans device if you NEED traction control to drive- It's completely logical and a valid argument.
                            I don't know many wheel to wheel racers here who NEED traction control or have monthly periods. Props to the female wheel to wheel racers there are a few here.
                            Many professional series cars are supposed race without traction control; Lots of cheating traction control noobs; the ones with real skills don't need it;
                            it is illegal and does make faster laps - If one needs to cheat like that to win what's the fun in the competition?
                            • demlotcrew
                              • May 2004
                              • 297
                              #74
                              Ha, Ive looked through your 'redneck' build, I can assure you the league you are in would be no contest, ABS on or off, I would still hand you your arse.
                              Yes I've raced, I don't need to knock people off the track to win ;)
                              Anyway, as much as I want to discuss your in depth knowledge in female sanitary products, I would much rather spend my limited time on something far more productive :)
                              PS, did you know everyone can see you editing your posts? Are you attempting to further reinforce your empty argument?
                              • Wanganstyle
                                • 2828
                                #75
                                only one who has never actually raced will be so stuck up.
                                It's funny you say hide from the fact you have never raced wheel to wheel. Try actual racing with contact; you won't survive with your attitude.
                                Your mom tell you to make sure the traction control is on when you leave home? Does she tuck you in at night still and tell you it's ok when Americans make fun of you?
                                It's fun to add more insults to the pile and see how your 4 banger loving fagtor will react.
                                Our 'merican redneck racing would make your euro queer club cry.
                                Don't want to be made fun of?
                                Stop posting on an American forum.
                                'MERICA IS A COUNTRY OF REDNECKS And you are not welcome here; you are unskilled and require traction control
                                And yes; I love NASCAR
