standalone s54 engine and DSC retrofitting into a e30
  • e30ixBoost
    • Dec 2012
    • 80
    #46
    Originally posted by nando
    Didn't look like an ix to me. Just proves you have no clue and are too condescending for any of us to help you. There was no attitude in my posts, that all came from you.
    ohh really , apparently you are unable to read, here let me show you my quote again
    Originally posted by e30ixBoost
    if it works for a e30, it will be made to work for a e30ix. I promise you that.
    here let me show yours again
    slowly think about it... if you still havnt caught on , theres nothing i can do for you
    END
      • 34844
      #47
      I guarantee nothing on that link applies to an ix. If you think so you are completely delusional.
      • e30ixBoost
        • Dec 2012
        • 80
        #48
        u still going on with that train of thought, i wont be sucked into improper argumentative ends that meet your goals
        you want to keep going this route, kicking and screaming, fine do it, if we all listened to you there wouldn't be any e30ix with 5 lugs.
        A post from 'Simple' in e30tech
        e30ix front rotor height is 35mm (hat and rotor). Using a combination of the e30m3 rallye hats and the e30 sport rotors gives you a total hat and rotor height of 35mm and 5x120 pcd. The calipers supplied in the e30 sport kit bolt on directly to the ix calliper mounts and with the e36 hubs in the front, everything should be a direct bolt on with maybe a few shims with the calliper to everything perfect.
        Other possible option I found is that the total height of a stock e30m3 rotor is ~40mm. As this is only +5mm over the stock rotor it may also work. I am not sure which calliper would be used, but I'm sure it would not be hard to figure out. This option would be muuuuuch cheaper than the above.
        there are even those who ventured into the 1 series solution. Thank god those people didnt listen to you.
          • 34844
          #49
          Lol, some of those posts you read were probably mine. Its funny you'd tell me about a thread that i contributed to more than a year ago as if you had some secret you could hold over my head.
          I don't know what "goal" you think i have? I literally was trying to be straight forward and helpful.
          • e30ixBoost
            • Dec 2012
            • 80
            #50
              • 34844
              #51
              I was talking about the E30tech thread. sheesh.
              and my other, earlier point was - there's no real benefit to 5-lug, other than looks. you could spend that money on a nice brake kit and shave off several pounds of unsprung weight. Any E30 BBK should work on an ix. The aftermarket kits also usually have the benefit of having cheaper consumables (rotors, pads) which is important if you're planning on tracking it a lot.
              On the RWD cars it's not as much of an issue, because a lot of stuff just bolts up. But getting the wheels bolted up is only half of the problem on an ix. Aside from not being able to run as much tire (because the wheels will stick out further) you're still basically left with a custom brake solution, that in the end is heavier and inferior than a good race BBK. and if something breaks you can't just order a new one and be on your way, you'll have to remake it from scratch. Since it has to be custom anyway, why not just go with aftermarket brakes and 4-lug wheels?
              The guys doing 5-lug on an ix do it for more of a project, or "just because" more than anything. or maybe they really want a wheel that only comes in 5 lug - but none of that makes any sense on a supposed dedicated race car, right?
              • e30ixBoost
                • Dec 2012
                • 80
                #52
                NOW that makes sense :D i honestly want anything greater then simple +1" extruding stance, so as long its near perfect of a stance of course so the transfercase and VC is naturally operating and under less stress. Defiantly no differences between front and back.
                Any big break bolt on solution which would be rapidly available and especially easily found for replacement of tires and rims is mandatory. I was always picturing the need more so in the 1/4 mile drag, not so much racing. Anyway this is still early and most important is the ability to keep DSC. The argument it self lost its value a long time ago, as it ballooned out of control about the 5 lug :firehop:...
                • DesertBMW
                  • Aug 2011
                  • 1040
                  #53
                  To answer your question Dynamic Traction Control simply can't work correctly on the E30 short wheelbase and semi trailing arm rear suspention
                  The semi-trailing arms have been criticized for the dynamic toe & camber changes inherent to the suspension geometry, causing bump steer in hard cornering situations (such as racing and autocross). This has contributed to the E30 as having a reputation for "tail happy" handling, where rear grip is reduced in certain situations, leading to oversteer.
                  Dynamic Stability Control is an innovative technology that combines the functions of traction control, braking enhancement, and cornering stabilization. DSC sensors continually monitor cornering-steering angle, transverse acceleration, yaw, wheel speed and brake pressure to instantly detect and correct loss of wheel traction due to slick spots, nasty weather, or emergency maneuvers. DSC helps you stay in control under all conditions, in any situation.
                    • 34844
                    #54
                    you aren't going to sheer 4 high strength lug bolts in an E30.
                    • demlotcrew
                      • May 2004
                      • 297
                      #55
                      I have a MK60 DSC III system fitted to my track car.
                      Soon to make a bolt on kit if there's enough interest. Also through a contact I am able to offer programming for the ABS ecu.
                      I'm also working on fitting the steering angle sensor to an E30 column to complete the DSC install.
                      In the UK there are a lot of S54 builds going on all of which want traction and speed sensor input so having the E46 ABS in and working is a must.
                      Any interest please contact me. It's early days and only small batch runs of kits are being made so only serious inquiries please.
                      Andrew
                      Andrew AT E30zone.co.uk | H23-is | S14
                        • 34844
                        #56
                        is your contact custom programming the ECU? flashing the CSL parameters?
                        you can do speed sensor input without DSC into MSS54, but not traction control of course..
                        I keep looking at DSC units out of E46s and people want way too much for the parts. I want to experiment with one if I can get it cheap enough to not worry about destroying it.
                        • demlotcrew
                          • May 2004
                          • 297
                          #57
                          Hi,
                          He is flashing a custom map which is far more suited for the E30 chassis and which surpasses the M track mode available on the CSL.
                          DSC units are very cheap here in the UK. You can get a complete working setup with connectors etc for around £200.
                          If fitting SMG in to the E30 at the same time as the S54 then DSC is essential.
                          It's worth the effort believe me.
                          Andrew
                          • DER E30
                            • Sep 2013
                            • 2349
                            #58
                            Originally posted by demlotcrew
                            Hi,
                            Andrew
                            Kool! I'll be back in this thread in a year or two... S54 swap in my future.
                            -Christian
                            • demlotcrew
                              • May 2004
                              • 297
                              #59
                              Lots of progress with this, I managed to get the MK60 DSC to run standalone with Engine torque control disabled, all DSC function is now solely done by the MK60 by applying the brakes. No other E46 system is in the car ;) no error codes and soon to have completed a modified steering column to accept the E46 steering angle sensor.
                              Andrew
                              • demlotcrew
                                • May 2004
                                • 297
                                #60
                                Steering angle in and working :)
