value of a m54 motor
  • ikonwun
    • Apr 2012
    • 374
    So I have come across a motor m54 3.0l with ZHP cams in it was thinking about swapping it into the E30 but was wondering if it would sell.
    This is just a motor no a/c, alt or pwrstr. no exhaust,throttlebody or DME.
    Has intake,injectors and motor wiring.
    What is the market for these motors. and if it worth trying to sell it.
  • ParsedOut
    • Sep 2005
    • 1437
    Probably worth it to somebody who overheated their 330i, I'd sell it and not bother with swapping it. Just my opinion.
    • ikonwun
      • Apr 2012
      • 374
      says the guy that just swapped a m50 lol.
      • DesertBMW
        • Aug 2011
        • 1042
        It is probably worth more parted out
        1. ZHP cams $400 easy
        2. 3.0L rotating assembly $500 easy
        3. vanos unit $80
        4. bare block $100
        5. cylinder head(no cams) $300
        6. valve cover $50
        7. intake manifold $50
        plus other parts
        so you are at $1480, easy. With that money you can buy nice M50 with everything you need for a swap.
        • ikonwun
          • Apr 2012
          • 374
          hummm.....
          well since you put it that way..
          will be making a for sale thread shortly. lol maybe
          • hoveringuy
            • Dec 2005
            • 2749
            Depending on the miles a ZHP motor is worth $1500-$2000.
            I would make a great swap!
            • ParsedOut
              • Sep 2005
              • 1437
              Wasn't saying you shouldn't swap at all, just saying you shouldn't swap the M54. :D I'm sure others in this subforum would disagree, but the M50/S50/M52/S52 route is much easier.
              • Wanganstyle
                • 2828
                M54 is a more advanced and smoother running engine due to double vanos and can-bus electronics; the brain is more advanced.
                M54 runs smoother than the original s52b32 dme in my 98 m3 although some sensors are shared. I have a m54 in my e46; its a really smooth nice engine.
                the e30 I race has a m50 but if a m54 could have gone into the e30......I'd prefer the m54 all day
                Sent from my SAMSUNG-SGH-I337 using Tapatalk
                  • 34844
                  yeah, what? the M54 is a better overall motor than the earlier versions. other than the S5x, it'll stomp all over any M50, plus it's significantly lighter.
                  Just because the electronics are more advanced? OBDII swaps are becoming more common.
                  • SkiFree
                    • Jun 2011
                    • 2766
                    My favorite use of an M54 would be Paul's 2002.
                    ADAMS Autosport
                    • ikonwun
                      • Apr 2012
                      • 374
                      Thanks for all the info.
                      I have started to collect parts and will hopefully be swapping end of summer 0r fall 2014
