M54 Madness, the remix
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Why the m50 manifold? The DISA valve and variable volume are what help give that motor such wide torque cruve, right?
    • DesertBMW
      • Aug 2011
      • 1043
      He doesn't care about torq, he wants peak power. M50 manifold flows a bit more. My personal opinion is that benefit will be very minimal, so minimal that is not worth doing.
      • hoveringuy
        • Dec 2005
        • 2754
        It's good for +10HP over a good range. The DISA does help down low, but the M54 intake is also considerably heavier.
        • CorvallisBMW
          • 13039
          I see. Carry on!
          • The Dark Side of Will
            • Jun 2010
            • 2796
            :-D
            • wannaBMthree
              • Apr 2007
              • 601
              Originally posted by hoveringuy
              Time and money....
              Giddy Up. Sub'd for the best engine to swap IMO.
              • hoveringuy
                • Dec 2005
                • 2754
                Current status is that the IAC bracket is fabricated.
                I'll be pulling the cams and then head in the next several weeks, need to figure-out what I'm doing as far as valve grind, guides and so on. It's a low-mile motor, so nothing probably needs to be done, but a good valve grind can make a big difference.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Awesome!
                  The OBD1 manifold drops torque, which you will notice. Seems like the don't "feel as fast" when you decrease torque, but this is going to be good, either way. The dyno graph you posted if from a thread I read recently.
                  john@m20guru.com
                  Links:
                  • hoveringuy
                    • Dec 2005
                    • 2754
                    Head is removed. Everything looks good except for some scoring on one of the exhaust cam journals. There was also enough loose carbon in each bore that I could vacuum it out; like a teaspoon of carbon was sprinkled on each piston.
                    Valves will be removed. Port will be matched to the new M50 intake manifold, the ports will be cleaned up a little bit (mostly exhaust!) and then the head will go to machinist for good valve cut and assembly.
                    • hoveringuy
                      • Dec 2005
                      • 2754
                      I borrowed the appropriate templates and cut the intakes to match the M50 manifold. With the right burr it took about 2 hours. Still need to plug the idle passages and do some minor work on the exhaust ports and then the head goes to the machinist.
                      The one on the left is done and the one on the right shows about how much material is removed. The blend goes about 1" into the port.
                      • bimmerboy12
                        • Jun 2004
                        • 1057
                        Subscribed - thinking of doing an M54
                        1988 325iC Project - FINISHED!
                        Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
                        • E30 Wagen
                          • Jul 2005
                          • 3434
                          Updates?
                          Can you comment on if it's easier to swap in one from a e39 vs e46?
                          My Feedback
                          • hoveringuy
                            • Dec 2005
                            • 2754
                            Originally posted by E30 Wagen
                            Updates?
                            I have the head ready to go to the machinist, but seeing as how I'm about to drop over $20k on siding I would't have the money to pick it up for a while, so it will go to machinist in September.
                            The e39 and e46 motors are the same as far as the swap. There are a few differences between early and late M54s. Some have 4 studs per exhaust port and some don't. That's an issue for me, because my euro s50b32 headers don't have the larger flanges that tie 3 runners together; they have an individual flange per port and my new motor doesn't have 4 studs per port, so I'll be getting new headers.
                            • mike25
                              • Jan 2014
                              • 27
                              Steve
                              Are you still developing this engine for your DD?
                              Having followed your original blog all the way, I'm struggling to understand why you are now giving up on DISA? Once you got it set up, you repeatedly showed how it helps with bottom end torque, and how that helps make your E30 a better performing DD with a very wide flat torque curve.
                              The dyno graph you have posted reveals more by what you have not shown - the loss of torque below 3750rpm. This appears to fly in the face of everything you have endorsed in your current swap?
                              What has convinced you to go with the M50 manifold?
                              Please don't tell us you have finally been seduced by headline power figures, and higher revving engines??!!
                              • hoveringuy
                                • Dec 2005
                                • 2754
                                Originally posted by mike25
                                Steve
                                You're right... DISA really does work. I'm still driving the original motor and the low-rpm torque is wonderful as it consistently chirps the tires. The downside with the entire intake is that I'm convinced it was optimized for transmission equipped cars driven by soccer moms that never rev above 4000 rpms. I remember when the car had the M50 and the way the power built into a crescendo was a very differenent feeling than what I have now.
                                I'm not completely lost to the dark side; I'm convinced I get achieve 250whp on this setup and the increase in power across a wide chunk of the powerband is irrefutable. It's the same effect as headers which may cause a small drop in low-rpm torque but more than make up for it with a broad power increase.
                                Add the fact that the m50 manifold weighs significantly less and looks cleaner; I'm willing to be a guinnea pig.
