M54 Madness, the remix
  • hoveringuy
    • Dec 2005
    • 2754
    Or the sequel, part 2, etc. We finally learn who Luke's father is...
    Anyway, I've been running the same M54 since the end of 2008 and it's been a great success. I've changed configuration on dozens of things, made lots of trips to the dyno and learned everything I would need for the second M54 swap.
    So, I picked-up a 85k mile motor out of a wrecked cream-puff e39 this weekend. It'll be easier to start with this motor than to pull my existing one and have the car down all year.
    The plan includes:
    -ArcAsylum subframe and notched oil pan. The e34 pan has always bugged me hanging out front.
    -Megasquirt wiring from the git-go. I've got a mashup of M50, M54 and "other" wiring harnesses
    -M50 intake manifold. The head will be port matched to the larger intake diameter.
    -ArcAsylum headers??
    Dyno data from a similar setup demonstrates 250whp.
  • digger
    • Nov 2005
    • 6212
    you need a seriously well ported head man, i hope it is on your list of to do? in all likely a set of custom cams to match the new found characteristics will do wonders. this is where you will find power IMO. then you could probably nudge closer to 300
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Excited to see this!
      • 325ix
        • Aug 2009
        • 7783
        I'm in for results as well. I've been reading up on m54's lately.
        • wazzu70
          • Jan 2005
          • 1143
          Very nice. Not worrying about the low hanging front pan will be nice!
          Does anyone make a set of nice cams for M54. I cant recall if you have the ZHPs but a proper set of cams will help heaps.
          Rewiring the car will be nice. When I installed my VEMS system I removed everything I didnt need from the factory harness (and added some extra wires for new sensors). It looks really clean, and there is no crazy splicing to cause headaches.
          -Nick
          M42 on VEMS
          • hoveringuy
            • Dec 2005
            • 2754
            Off to a good start..
            Removed my valve cover and it's as clean as I could hope. The cam lobes are gorgeous. This motor has had a good life!
            Also picked-up an M50 intake manifold.
            • MasukBMW
              • Sep 2006
              • 325
              Updates? Thought this build would fly this time
              • hoveringuy
                • Dec 2005
                • 2754
                This wont' necessarily go that fast. I have lots of other things competing for my time and money...
                Anyway, I did go and pull a complete M50 intake the other weekend. Came with absolutely everything. After pulling some of the extra studs on the head it bolted-on beautifully.
                The support strut to the block was a quick and easy mod.
                The current task is that I need to locate and mount the ICV. The m50 has it attached to the block at the wiring support bracket. The M54 has it attached to the bottom of the manifold. I would prefer to have it on the bottom of the manifold so that it will lift off as one assembly, so I need to resolve that.
                After that, I'll pull the head and match the ports. My latest intel is that the motor had closer to 67k miles, so the head won't need any work, but I'd still like to match the valve guides to the port wall and other minor porting.
                I also purchased a spare front subframe.
                • 2mAn
                  Señior Mod
                  • 21083
                  I'll be watching this.
                  *side note* Thanks for all your help with my car. Im picking it up tonight.
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • klodkrawler05
                    • Apr 2012
                    • 253
                    subscribed for more updates, the M54 is in the back of my head as a replacement for the S52, I'm content with the power it provides but would enjoy knocking 50-60lbs off the front of the car
                    -Brad
                    My E30: http://www.r3vlimited.com/board/show...50#post3916850
                    • Roysneon
                      • 4505
                      Are you going to run this off of the M54's original DME or a 413? Or Megasquirt?
                      Originally posted by mbonanni
                      I am a pursit now.
                      • hoveringuy
                        • Dec 2005
                        • 2754
                        Megasquirt.
                        The MS43 is a great ECU but it's not as easy to tune and maintain as the Megasquirt. Plus, I can easily add traction control and some other cool functions.
                        My current status is that I'm fabricating the the ICV bracket. After that, the head will come off.
                        Time and money....
                        • mkcman17
                          • Jul 2010
                          • 8240
                          I have a 105k m54 with manual harness, someone come give me $900 for it!
                          1989 LN106 Hilux / 3.0TD SFA
                          1974 2002tii / stock
                          2002 IS300 / 5spd LSD
                          • kalib0y
                            • Dec 2004
                            • 3620
                            subbed
                            95 7.1L 16V E36 M3
                            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                            LIKE my Facebook Page! CLICK HERE
                            • stonea
                              • 2892
                              Subscribed, I'm seriously thing about doing a M52TU swap into my ix. I may have questions for you about the Megasqurit and the wiring.
                              My Garage
                              Feedback
                              Instagram: Stone.Hopkins
