S54 Swap Exhaust systems
  • e30polak
    • 6136
    Originally posted by Luke_M
    If I had to do it over I'd probably still use the Borla but use a Vibrant Streetpower Muffler for the fancy tips. I've read that the vibrants aren't to loud so I don't think it would affect it much. If you wanted it even quieter you could use a turbo style muffler. However, I chose not to do that because the cfm numbers were all pretty lousy on those.
    Vibrant Street Powers are one of the loudest mufflers out there. I know, as I've had them on most of my cars, and it takes a quieter center muffler to keep the Vibrant tame. They do however have a great tone:
    My old s52 e30 with a Borla mid muffler, and a Vibrant rear muffler, with ebay SS headers and 2.5" single exhaust:
    INSTAGRAM: @UNDR8D_EMPIRE
    • 95///M3
      • Mar 2005
      • 181
      I have been running 2.5 dual from headers down to a 2-1 2.5" collector. Single 2.5" the whole way back. Goal was to keep it close to the floor boards and quiet. Still make over 300whp with tune.
      • digger
        • Nov 2005
        • 6128
        Originally posted by e30polak
        It's a fairly short height muffler, one of the lowest profile mufflers out there.
        yeah only 4", i used two 3.5" hotdogs to improve clearance but 4" would still be ok and xs would work better i feel
        • BMWfanz
          • Dec 2013
          • 46
          Does someone lost HPs and torque in swapped e30 with custom exhaust? I saw a lot of opinions that custom exhaust make lower HP than stock e46 system (about 20HPs). Is it true?)
          • 328ijunkie
            • May 2007
            • 3961
            We dont do alot of different exhaust setups for these cars, typically use off the shelf setups but the few we have done and the tons weve tuned ive learned a few things.
            The closer to the manifolds the merge is coupled with a larger diameter single= horrible down low <3K rpm scavenging. This car has Epic headers and merge to a 3" with a race cat, vibrant muffler and res. (run 3 was untuned before cat, Next run is after cat with a base tune, then after final tweaks)
            Trimming AFRs and vanos as much as possible i trimmed out the down low freakout but there still is a massive torque loss because of merge placement. But on the other hand, every car ive tuned with the merge like this, rips on the top end because of it... Everything is a compromise.
            Check Us out on Facebook
            Full Product Line Tuning
            • e30polak
              • 6136
              The single 3.5" cars typically make 8-12whp more up top, and maybe hold 5-10wtq better to redline. It really depends on gearing too. If the car has short gearing, than sub 3k rpms are never an issue. Longer geared cars, especially heavy e46 m3s, will feel this more, and it's more apparent in higher gears. Good headers obviously effect the power band as well. Epic headers probably cause a bit of the bottom end loss as well do to their large primaries, but they make up for it above 4k where it counts on a track car.
              Personally I think a proper dual system will always sound better than any single system I've heard.
              • digger
                • Nov 2005
                • 6128
                yeah, a single exhaust is lighter, cheaper, easier to produce and has more potential but the dual sounds better and offers slightly more clearance
                • BMWfanz
                  • Dec 2013
                  • 46
                  Could someone share XDF file for tuner pro? i have mss54 211322002101 version of soft. The reason why i'm asking cause there is no possibility to tune my car by evolve and other stuff cause there are some tunes that must have to be tuned online on dyno, and in Kazakhstan there are no specialists who can make it. My friend have a lot of expirience in M50 and S50 engines, but he doesnt have XDF for my ECU. Would be pleased if someone able to help me with it)
                  • e30polak
                    • 6136
                    And dual makes better torque below 3.5k and has better exhaust scavenging around town. In a light e30 there is still plenty of torque even with a single exhaust though.
                    • digger
                      • Nov 2005
                      • 6128
                      not really, those that lost torque down low going to a single exhaust gained it back when they put the merge in a more suitable location
                      merging from twin collectors into a Y or X pipe is going to be much of a muchness. the single exhaust might have a topend advantage because the Y-pipe is going to flow better than an X-pipe with the same outlet cross sectional area simply because the shape is better.
                      both 3" exhausts
                      even 3.5" exhaust done properly still make excellent bottom end
                      • Luke_M
                        • Aug 2011
                        • 275
                        https://www.youtube.com/watch?v=r2H5YreLZqk
                        Well shoot dang! I'm glad you told me before I pulled the trigger on one. Is it much worse then a universal magnaflow? Any advice on a 3" high flow muffler with purdy dual tips?
                        hows the ground clearance with borla proxs there? are you lowered?
                        Very much lowered. It's not bad at all. It fits pretty well just below the driveshaft. Here's a good thread from Nando: http://www.r3vlimited.com/board/showthread.php?t=183420
                        Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
                        • frantic
                          • Mar 2008
                          • 62
                          Which Ebay Headers does everyone use and how much modification?
                          I have some Euro E46 M3 ones, the front section won't even fit down between engine and chassis rail to see how bad that is, Rear one the #6 fouls on the firewall and may or may not just clear the steering.. Joys of RHD!!
                          • diesekte
                            • Sep 2013
                            • 417
                            Can an S54 E30 make use of the full length of an E46 M3 section 1? I was hoping to Y after the section 1 if possible to a 3"
                            • diesekte
                              • Sep 2013
                              • 417
                              Bump, anyone know about section 1?
                              • burkey001
                                • Feb 2011
                                • 608
                                I will hopefully be able to add a dyno graph to this page soon.
                                Buttoning up my S54 swap, have my exhaust now done.
                                Custom headers, custom mid section, E36 Eisenmann M3 rear muffler. I realize it may be 'a bit' raspy with no centre muffler. We'll see. :)
                                It's dual 2.5in
                                RHD car, so steering clearance is the main limiter for making headers...
                                88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                                90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
