Kassel S54 Airbox
  • Best_name_available
    • Jul 2014
    • 479
    #31
    Originally posted by Northern
    This is the best thread going on r3v right now, with all the Hakkjobtt bullshit and all.
    And just like that, thread is dead
    Originally posted by Vokuhila
    I laughed, and then I serioused
    • e30polak
      • 6136
      #32
      Since this has turned into a make fun of Haken thread, I'll keep it going!
      His new project build on bimmerforums!
      INSTAGRAM: @UNDR8D_EMPIRE
      • iliad
        • 474
        #33
        So much bad information out there.
        Using the revshift engine mounts, 944 brake booster slid over 1/2" and slightly modified, requires zero modification to the airbox.
        • Staszek
          • 2533
          #34
          Awesome info, what do the revshift mounts do that make the difference?
          • iliad
            • 474
            #35
            I went with revshift because I wanted isolated poly engine mounts, I don't think they are any different, just a high quality mount.
            I could space up the driver's side with a couple washers and do less modification on the booster.
            The csl replica airbox is harder to fit then the stock airbox.
            • Staszek
              • 2533
              #36
              Thanks, so I can stay with the stock airbox, save a ton of money and go 944 booster with a bit of movement.
              Sounds like a plan!!
              • iliad
                • 474
                #37
                Abolutely.
                A bit of movement and slight massaging of the booster OR space the driver's side mount up a little.
                • diesekte
                  • Sep 2013
                  • 417
                  #38
                  Or use the 2002 booster. No spacing or shims required. I've driven on it a bit and it's nice - 2002 booster with stock e30 master feels exactly the same as my previous setup (ix booster and 7er master)
                  • Staszek
                    • 2533
                    #39
                    Really? Everything I heard is that the 2002 booster is weaker the stock.
                    • e30polak
                      • 6136
                      #40
                      You must have had a bad booster or master before. The 2002 booster is smaller than the e21 booster, and when I had that on my s52 e20, I needed a vacuum reserve canister as the assist was so much weaker.
                      On my s54 M3, I did the iX booster, and it gave even more assist than the original m3 booster.
                      • diesekte
                        • Sep 2013
                        • 417
                        #41
                        Master and booster were both good. I have the e46 m3 front and 5 series rear brakes...no complaints
                        • DesertBMW
                          • Aug 2011
                          • 1028
                          #42
                          Originally posted by nando
                          HakkenTT. AKA "rebuilt engine with used rings" aka "blatantly copies peoples tunes" aka "hacked up E36 N55 swap" and many others. He's prolific on all BMW forums.
                          I am still here Nando, where are you at? you are just jealous of my technical abilities. You are the one who bought other people's tunes and made it like you discovered them via code disassembly. And by the way my E36 N55 is still running after 10 years.
                          • TobyB
                            • 5198
                            #43
                            Whoah- ho! R3v is R3z3n!
                            t
