S54b32 Camshaft
  • wannes
    • Aug 2012
    • 23
    S54b32 Camshaft
    Dears,
    does S54b32 camshaft fit on M54b30 or there is different in overall size so it can not fit on the cylinder head of the m54b30 ?
    your reply is so appreciate .
    Regards.
  • digger
    • Nov 2005
    • 6170
    you can use a modified S54b32 crank in a S52B32 block so my guess is it would work with mods. its not a direct drop in
    • wannes
      • Aug 2012
      • 23
      but my question is about camshaft not crank ( if the s54b32 camshaft fit on m54b30)
      • digger
        • Nov 2005
        • 6170
        yeah my bad lol.
        ill say no forget about s54b32 camshafts they have finger follower design totally different to m54. goto schrick or catcams if you want bigger cams
          • 34844
          No. The s54 head is completely different. They will not fit in an m54.
          If anyone happens to be interesting, i have a set of good s54 cams collecting dust on my shelf. :-P
          • stonea
            • 2892
            Thats interesting about the S54 crank though.
            My Garage
            Feedback
            Instagram: Stone.Hopkins
              • 34844
              Not sure its a good idea to put an S54 rotating assembly in an aluminum block that already has harmonics issues.
              • digger
                • Nov 2005
                • 6170
                or why you wouldnt just use a s54 in its entirety...MM used to or still do use offset ground S54 cranks in S52 iron blocks
