M54 - MS45.0 & MS45.1 swap flashes available
    • 34839
    Based on his option codes I think 7550101, 7550099, or 7550097 would be your best bet. I believe all of the others are for low compression engines, mostly for Asia markets. I would start with 7550101 and see how it runs.
    • armenh7
      • Jun 2018
      • 15
      Thank you very much. I will go ahead and try it out
      • armenh7
        • Jun 2018
        • 15
        I'm afraid the DME was killed. As I was updating, I got this error. https://drive.google.com/file/d/1Isf...w?usp=drivesdk. Now inpa doesn't communicate with the DME neither doesn't winkfp
          • 34839
          I don't think that means it's killed. But you may need to update the program to match whatever ZB# that is first, which should be 7549387A.0pa.
          security access denied means the RSA signature check failed. but when you start the flash, the first thing it does is erase the parameter section, so it's not going to talk to INPA until it's flashed.
          I would try the 0pa first, and then try the 0da again.
          • armenh7
            • Jun 2018
            • 15
            So I just retried it and it worked. I'm afraid to try the other flahses now though. The guy did say it's running a bit lumpy but I see a ton of errors
              • 34839
              It would honestly be really tough to brick it. You can't write to the boot code on MS45, so there's no real way to break it outside of physical damage.
              You probably need to reset adaptations (engine off, ignition on), start it up, clear codes, and restart again.
              • armenh7
                • Jun 2018
                • 15
                I went ahead and flashed 99 and cleared adaptations. Failed to start 2 times but this third start it ran and the idle is much better
                Spoke too soon. Lumpy idle is back
                I tried flashing all three. 99 and 97 ran better than 101 but it seems to break up after a minute of running
                  • 34839
                  ahh, you know what I didn't even think of this properly. He needs to run the tune for an M54B30. Also, the power class has to be modified to match his original value stored in the car.
                  • armenh7
                    • Jun 2018
                    • 15
                    Yeah I needed the tune for a B30 lol. He swapped it into the car. Any insight on that?
                      • 34839
                      actually, MS45 doesn't have a power class - 7550125, 7550127, 7550129, and 7574504 are all for an ECE 530i. Same program version.
                      • armenh7
                        • Jun 2018
                        • 15
                        I'll try those out and report back
                        • armenh7
                          • Jun 2018
                          • 15
                          7574504 seemed to keep the engine the happiest. Now to figure out the o2 sensor errors, crankshaft, camshaft, and BSD errors
                            • 34839
                            Great!
                            Probably on his end. I can delete codes and make a signed MS45 file, but not for free. ;)
                            • armenh7
                              • Jun 2018
                              • 15
                              Great!
                              I don't think masking the codes is a solution yet ;) the engine runs a bit rough when revving. The cluster loses rpm reading above 1500rpm so the errors are actual. They're all signal errors but he said he didn't touch the wiring
                                • 34839
                                Right, i think those are all probably sensor/rpm errors. A "wrong" tune shouldnt cause those problems.
                                Did he use the sensors/harness from his old motor or from the new one?
