M54 - MS45.0 & MS45.1 swap flashes available
  • armenh7
    • Jun 2018
    • 15
    #31
    Originally posted by nando
    Right, i think those are all probably sensor/rpm errors. A "wrong" tune shouldnt cause those problems.
    Did he use the sensors/harness from his old motor or from the new one?
    Old motor. He went from a M54B22 to a M54B30
      • 34839
      #32
      That may be his issue - some of the wiring and sensors could be different.
      • armenh7
        • Jun 2018
        • 15
        #33
        I looked up the wiring on newtis.info and it all checked out to be the same. I'll ask him to see if he can try another harness
          • 34839
          #34
          Crank sensor may be different. I know there are differences in MS45 and later DMEs, the inputs don't all work with the older sensors.
          • armenh7
            • Jun 2018
            • 15
            #35
            I feel like it's an input issue too. I verified part numbers with realoem and they're the same
            • ForcedFirebird
              • Feb 2007
              • 8300
              #36
              Thanks for all your help in the community!
              john@m20guru.com
              Links:
              • armenh7
                • Jun 2018
                • 15
                #37
                Agreed!
                • CLASH
                  • Nov 2013
                  • 39
                  #38
                  Can you tune MS45.1 for turbo built?
                  Thanks
                    • 34839
                    #39
                    It can be done yes, but FI is a bit more work than the usual tunes I do.
                    • 95///M3
                      • Mar 2005
                      • 181
                      #40
                      Echo'd. Thanks for all of your dedication and hard work!
                      • CLASH
                        • Nov 2013
                        • 39
                        #41
                        What would be better ecu for M54 E30 swap and turbo would like Haltec or AEM ecu work for it?
                        Thanks
                          • 34839
                          #42
                          Sure, you can run anything on standalone.
                          Go whatever is easiest for you to get tuned. a $10k fancy standalone doesn't do you any good if it's running a crap tune. What's nice about a stock DME is all of the 'drivability' stuff is already done out of the box, and the diagnostics are way more advanced. The standalone gives you a lot more flexibility, but nothing will 'just work' like the stock DME - it can be just enough rope to hang yourself with if you don't know what you're doing.
                          • CLASH
                            • Nov 2013
                            • 39
                            #43
                            Still offering the service?
                            Thanks
                            • Solarian
                              • Oct 2012
                              • 121
                              #44
                              Hi, are you still doing this? I tried reaching out on the website and got no response
                              • jchap808
                                • Nov 2023
                                • 16
                                #45
                                Any chance this thread can get bumped. I need you Nando
