M54 - MS45.0 & MS45.1 swap flashes available
    • 34844
    Just putting this out there for anyone looking into the M54 swap - I'm developing a complete swap flash for the M54 using MS45.0 (narrowband O2 sensors) or MS45.1 (wideband O2 sensors).
    It includes:
    EWS Delete (of course)
    CAN bus delete
    Post-cat O2 sensor delete (with monitors enabled and "ready")
    cat-warmup delete
    cat-overheat protection delete
    DMTL delete
    SAP delete
    VSS limiter delete
    Sport switch enabled
    Probably other things I've forgotten.
    many of these mods require program code modifications - you probably won't find this anywhere else. :)
    The DME has to be sent to me for the flash (MS45 is RSA encrypted). Turn around varies but I try to keep it to 2 weeks. If it's a pretty basic M54B30 swap with the features above, it should be fast - if there are special requests, it will add more time.
    I can also do MSS54 (S54), MSS52 (S62), MSV70 (N52), and MSS70 (S54). Should be able to add MSS60/MSS65 in the future as well.
    PM if interested for more info.
  • hoveringuy
    • Dec 2005
    • 2747
    This is really cool! For an M54 swap this is the way to go.
      • 34844
      Yeah - I'm not neccesarily against standalones, but the stock computers are so robust and adaptive they make 95% of them look like 8 bit Nintendo. I was an early adopter for MS3, and as good as it is I've lost all interest in it.
      Never having to deal with surging idle, hard starts, random stalls and jerkyness is awesome. Just tweak the maps that matter and leave the rest perfectly stock!
      • AudioNToxication
        • Nov 2013
        • 117
        Whats the solution for cruise control looking like?
          • 34844
          It should be possible to make it work. The main thing is whether the 9-tooth vss input will be good enough. There's a branch in the vss code that subsitues the calculated signal for the CAN signal, so if it works at all it should be possible to activate. I'll look into that some more.
          • BraveUlysses
            • Jun 2007
            • 3781
            so does MS45 and 45.1 work with any M54B30 motor or does it only work with certain years?
              • 34844
              should work with any M54B30 motor, but there are likely differences in sensors and definitely harnesses. I think MS45 replaced MS43 in 2003 or 2004, they also came in a bunch of newer cars like the E60 5 series, earlier X3, Z4, etc. It's probably easiest to just use whatever comes with the motor - IMO, the newer, the better.
              • E60
                • Aug 2016
                • 2
                Just sent PM for you nando. Doing swap for my E60
                • wazzu70
                  • Jan 2005
                  • 1143
                  This is really cool. Good work!
                  -Nick
                  M42 on VEMS
                    • 34844
                    I learned on MS45.1 that extra components need to be added to enable the sport switch. I can do that if requested (for a little extra of course - they are small SMD parts). BMW had to save 1 cent per DME on the MS45.1 variants. :|
                    • armenh7
                      • Jun 2018
                      • 15
                      MS45.0 E60 M54B30 Swap
                      Hi nando, hopefully you see this. Hello everybody, I was helping somebody over at e46fanatics but I came upon an issue. The op lives in UK and has a E60 520 that he recently swapped a 530 engine into. The DME is a MS45.0 but I'm having trouble finding a proper ZUSBnumber for it. I've looked through realoem but I cannot input any of the numbers I come across into WinKFP because it doesn't exist in the configuration file. I hope somebody can help me find it
                        • 34844
                        what's his serial number?
                        • armenh7
                          • Jun 2018
                          • 15
                          WBANA3201B340695
                          Here are the zusbnumbers given in winkfp
                            • 34844
                            I see about 12 matches depending on options, but probably any of them would work.
                            WinKFP isn't perfect unfortunately. Actually, BMWs records on this are just terrible all around. He's lucky he has an E60 and not something older, because for E46 and earlier based vehicles it's even worse.
                            • armenh7
                              • Jun 2018
                              • 15
                              The weird thing is that I've updated at least 10 different e46's yet I've had no issues. This E60 has got me stuck because I don't know which zusbnumber can be used
