Walbro 255HP in non 24V
  • Staszek
    • 2533
    So as I was working through my project i noticed that my gas tank is dented. I am considering options to change it, but while its down if I did change I would need to switch the pump over.
    Could I put the Walbro in now even though I havent switched to the S54 yet? I really wont be driving the car much at all, but I may be starting and moving until I pull the engine.
    I really dont care much about the M20, but will it hurt if I switch the pump now?
  • PA_Welder
    • Feb 2016
    • 82
    No it should be fine the fuel pressure will still be the same because its controlled by the fpr not the fuel pump
    • Staszek
      • 2533
      Ok thanks, actually I may just use the OEM S54 Fuel Pump, I am hearing that works fine.
      • parkerbink
        • Jun 2004
        • 10138
        I replaced my failed pump with one on a mostly stock M20. Works fine.
        • Staszek
          • 2533
          Great, which part number did you use?
          • parkerbink
            • Jun 2004
            • 10138
            This is the one I got:
            https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
            • Staszek
              • 2533
              Ok thanks!
              • rjmcdermott81
                • Oct 2014
                • 565
                I don't know if this is the case for all the Amazon sellers but I ordered that same pump on Amazon and when it arrived it didn't appear to be authentic. Walbro has a whole webpage dedicated to determining if what you get is legit. I ended up returning it and then ordering direct from Walbro. My return reason was "Not authentic" and the seller never argued about it....
                The one I got from Walbro had a sock that wouldn't work though so I bought this one from Autozone: Delphi BFS0187
                Build Thread: Ryan's Hennarot 318is
                COTM Aug 2019
                • parkerbink
                  • Jun 2004
                  • 10138
                  The one I posted came with a sock that was a pita to get in there but I made it work.
                  • stonea
                    • 2892
                    You'll be fine with what ever fuel pump you choose, but I vote for e46 M3 fuel pump. OEM FTW!!!
                    My Garage
                    Feedback
                    Instagram: Stone.Hopkins
                    • Staszek
                      • 2533
                      Still thinking about that but at $400 damn, especially with all the other damn things I am buying!!
                      • stonea
                        • 2892
                        Buy it through FCP Euro and only buy it once.
                        My Garage
                        Feedback
