Engine options
  • JNe30
    • May 2017
    • 3
    Engine options
    Just getting started researching for a s54 swap. Started looking at available engines and am wondering if it matters if a motor came from a car with smg trannsmission? Thanks for any help
  • R3Z3N
    • Jan 2011
    • 3056
    ^No, however the ECU will need to be programmed to know you have a manual. Unless of course you plan on using the SMG.
      • 34830
      Doesn't matter. DME has to be flashed either way - it's only 2 bytes to change from SMG to a manual.
      • Wolfman
        • 341
        Choose an 04-06 engine
        • cwlo
          • Sep 2015
          • 131
          Also, if you're not up to speed on the S54, get acquainted with its weaknesses and needed updates....namely rod bearings and vanos/cam.
