I’m thinking of switching up motors, I want more power as the m54 is giving me a taste of V8’s but it’s just too much of a tease. Engine runs great with 81k on it and many gaskets and lines replaced. So I was wondering how much the entire drivetrain would be worth. Including:
The engine:
M54B30 (originally pulled out of a crashed e39 with ~73k miles, now has 81k)
new Vanos line, valve cover seal, coolant hoses, m42 radiator brand new, new water pump, plenty of fresh zinc plated bolts, etc does not come with headers, or a harness, ECUs has been tuned and flashed by hankett in 2015.
The transmission/shifter:
G260 with ~140k, brand new slave, chase bays clutch line, stock clutch and wheel, shifter is in good condition without a ton of play in gears.
Driveshaft, new cab, zinc plated steering rack link, RSI turbo manifold with no miles, Chase bays power steering kit and lines, brand new e28 mounts, stock fuel lines with zinc coated pieces, new fuel filter with zinc plated bracket, stock e30 fuel pump and e46 m3 fpr. possibly a fresh powder coated/reinforced front subframe (depending on what motor I get)
How much do you think this is worth? It is a 100% drop in kit, all you need is an exhaust and manifold, plus a harness and it is ready to drive. I can include compression numbers and an oil analysis. If I can’t get any money out of it I will probably just stick with what I have because it is still a blast to drive with a 3.46 lsd.
Thank you in advance.
The engine:
