S54 swap?
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
e36 with s54s can be fast!!! look up Vic Sias's autocross e36 car with s54.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I'd agree with you. Most of the swapped cars on here don't have very well sorted suspension set-ups. Without dialing it in probably the added weight of the motor over the nose, and the added torque can really turn into a handling disaster. :p
Then again my swap car was pretty dialed in, and it handled on rails. :nice:Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
if it handles like its "on rails"..... you're not driving it fast enough. :)
son, you got to dial in a little more "right foot!" handles on rails...... with an s54...... sheeesh.
I've figured out how to do it, just have not released any kit to do so. My method requires a software update plus either a hardware mod inside the ECU, or a a small circuit outside the ECU.URL: www.dsylva-tech.caComment
Interesting
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Mike from StanceFactory up here in Toronto had his S54 E36 running for a while, I think last year it was. I heard it was before Burroughs, he was down at H20. He's running all factory wiring and DME's everything works, even sport mode.1985 325e 2.8 Turbo VEMSComment
Nice project!
Bear me in mind if you need a way to get the engine running oem style.
Cheers
TurkComment
I worked on the software for an S54 into E36 swap in 2005, who can beat that one?
And I have an E30 racecar with s54 swap running in Toronto right now.
MarkDURL: www.dsylva-tech.caComment
