S54 swap?
  • matt
    • 3732
    #121
    Originally posted by FredK
    Oh? Is deleting DSC over CAN on that list too?
    Of course.
    • e30polak
      • 6136
      #122
      There is already someone that can get the s54 and s62 running on the factory DME in your e30, with wiring instructions for 900 euros, but you have to send your DME to Germany. ;)
      INSTAGRAM: @UNDR8D_EMPIRE
      • moatilliatta
        • 6158
        #123
        The good old knowledge of the motherland. Who would that be?
        @Zakspeed_US
        • MattM
          • Apr 2009
          • 931
          #124
          they are out there... One of my friends provided the engine for this one
          Full Build Thread Here
            • 34847
            #125
            Originally posted by e304me
            Has anyone thought of just using megasquirt? I think they should be able to control vanos by now?
            there haven't been enough people testing the vanos code so I don't know if it works directly, but it can totally run it on a fixed map with a couple of the spare PWM outputs - MS3 of course.
            • hoveringuy
              • Dec 2005
              • 2754
              #126
              The VANOS is the easiest part to control on the S54. 10X easier than the M54! No PWM is even required... With two solenoids per cam one is the "fill" and one is the "drain". Fill until you get the right position and stop. The cam is hydraulically locked in that position until it's moved again.
              As far as Megasquirt, yes it can be done... the challenge on the S54 is that the cam sensor wheels on the S54 look much different than what we're used to on M50s.
              If I ever get my hands on an S54 I would like to adapt my VANOS board to both control the cams AND to translate the s54 cam signals into M50-speak so that Megasquirt/413 ECU's could run it.
              • balooshinakus
                • 511
                #127
                If I bought an s54 would you want to do it to my car :-P
                • M3 euro ltw
                  Site Sponsor
                  • 259
                  #128
                  Omg
                  Saturday got my street car, E36 325is (M-Technic actually) running and on the road with the DTA run S54.
                  CF intake, motorsport clone with 8 inch opening
                  Euro headers, ie no cats
                  AA E36 race exhaust, straightpipe, no resonator
                  Otherwise stock engine
                  OMG...raped ape fast.
                  WAY too loud for street with the AA exhaust without resonator, will HAVE to fit something different asap. Hope the resonator will be enough for the street once put in, the quality is fine on all the parts, using BW converter part to the headers with minimal modification.
                  Will have locals driving it during the next week or so to chime in...
                  Needs some fine tuning on cold start etc...what a blast.
                  Trying to make the world a better place, 6 TB at a time.
                  http://abloriginalparts.com/
                  • Ray Smoodiver
                    • Jun 2004
                    • 8809
                    #129
                    Pics ASAP :D
                    • M3 euro ltw
                      Site Sponsor
                      • 259
                      #130
                      Yea, working on it.
                      I'm picky (a bit) on appearances, looking to find a source for the superflexible silicone hose in 22mm or 1 inch ID. (Black version)
                      Have a run of it in blue, and it takes away from the appearance of the install.
                      Also, the euro heat shielding made contact with the fan, not sure why, should have worked, but I'm uncertain as to which clutch/fan I put on from a stack of them off the shelf. First one had a bad clutch, so that was no help.
                      Second rubbed. My home brew alum 1/4 reservoir tubing will look better in that shield...
                      As a completely silly side issue, its a nice swap from a leaky M50 to a clean engine too, freshly helicoiled sections on the oilpan, and different PS system that doesn't leak etc...
                      Will post up really soon, too fun not to share the enthusiasm. I know this is an E36, but it will work on your guy's cars as well.
                      Alex.
                      • e30polak
                        • 6136
                        #131
                        Hey Alex, how does it feel compared to Jason's E30 M3? ;)
                        We need dyno results!!!! :hitler:
                        • moatilliatta
                          • 6158
                          #132
                          DTA ran s54?
                          @Zakspeed_US
                          • e30polak
                            • 6136
                            #133
                            Originally posted by moatilliatta
                            DTA ran s54?
                            Ya, Alex has had some great results so far.
                              • 34847
                              #134
                              you could change the cam signal on the S54 to basically whatever you wanted for MS. a missing tooth wheel pattern would probably be best. or supply the developers with the required information and have native support. :)
                              • M3 euro ltw
                                Site Sponsor
                                • 259
                                #135
                                Jason's S54 and mine
                                We've developed these side by side, but they're not identical.
                                My headers and intake are probably flowing better than Jason's, only because I had invested long ago in a set of euro stock headers, and I'm running temporarily the CF clone of the airbox.
                                That having been said, Jason's car would cream mine even if I have a few more horsies, his car has better weight balance, and best of all WAY LESS weight.
                                I'm running AC, full stock E36 interior etc....I'd have to guess his car is near to 2200 lb, mine closer to 3200.
                                No comparison for the actual cars....And any of you dropping same motor into an E30 will also realize the benefits of less weight.
                                Alex.
