So what are the big differences between this and an S50? Have you driven multiple swapped cars to compare?
M54. Let the foolishness begin.
Originally posted by hoveringuy View PostYou're power curve looks much different without VANOS and DISA, but 250 torque... holly sh!t.
Great job!89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Originally posted by justice101 View PostSo what are the big differences between this and an S50? Have you driven multiple swapped cars to compare?
I've always felt that the M54 was a better street motor and the S50 is a better track motor.
S50 has a better head that breathes easier, but M54 DISA/VANOS make more torques.
Originally posted by Elysian View PostSo what are you doing with the engine harness/ecu setup for the M54 is you go S54? :D
If anyone ever wants to meet up you're welcome to take my car for a drive (within reason).
Originally posted by hoveringuy View PostS50 has less bottom end. My car has more torque at the bottom end accelerates quicker off the line until around 5000 rpm, when the S50 feels stronger.
I still need to purchase an S54, but the M54 would be sold.
If anyone ever wants to meet up you're welcome to take my car for a drive (within reason).Leo.
E30 318iS, E36 328i
250rwtq is about 295lb-ft @ crank. That would be about 98lb-ft/Litre which is just not possible in reality regardless of whether there is a printout that says it. The BMEP is too high. It would have to be the best NA engine every built to make those numbers.
Do the maths and physics, read off the graph the power is approx 193rwhp@5000rpm (by eye)
Power = Torque x rpm / 5252
Therefore Torque = 5252 * 193rwhp / 5000rpm = 202rwtq
The numbers don’t add up.
The power figures look normal maybe the rpm pickup is faulty or the curve is not rwtq but some other value.
Some times with dyno dynamics they convert rwtq to tq by correcting for coastdown losses (about 20% is a ballpark number) but there is usually a ‘S’ near the units to indicate this.
In any case the car doesn’t put down 250rwtq.89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
As a reminder, here's about the best I got. The M54 just doesn't flow that well and a bigger bump on the cam won't help that.
Does fantastic on the bottom but doesn't carry as well as an S50.
This is with ZHP cams compared to normal cams. I got a few more hp.
Here's my M54 vs an S50. Same dyno back to back.
Thanks for the comparison. Good to see how the M54 compares to the S50. I'd like to see the torque curve of the S52 compared to these as well."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER/SCHWARZE
(within reason).
*** i have a full set of s54 sensors hereLast edited by Wanganstyle; 06-01-2011, 09:26 PM.OBD1 M54/M52TU swap as a M50b25
I did get to use the benefits of the M54's torque to great advantage the other day.. raced an e39 540i.
It was a steep on ramp, about 7% grade, with two lanes that merged into one about 500 feet up. Stop light at the bottom.
e39 was behind me and I couldn't tell if he was just going to follow me up and be mellow or..
..try to blow by me in the right lane.
Light turned green, I took the left lane and he swung right and floored it for the kill on a hapless, old e30. Game on!
I floored it in turn at the bottom of second gear and the grade kept the rpms low in the rpm band for an inordinate time. DISA is magic in the 3200 rpm area. I stopped his pull and he slowly drifted back off my quarter. I saw the smug leave his face.
He conceeded the pass and trailed me into the merge, I slowed for traffic while he blew through the marbles and passed me to the left in the "no man's land" between the freeway and the on-ramp. A ricer fly-by!
The 540i is a 14.0 second car with tons of torque, so I felt pretty good about it. That's what I love about the M54.
