I’m joining the club
  • LukeJ
    • Jul 2019
    • 139
    When installing and removing the N52, I would use a ratchet strap to prevent the engine from rotating counterclockwise. I hooked it to the eye on the hoist and then to the engine arm. There is a metal portion of the valve cover where the strap will lay, that seems to be made for this. Once I started to lift the engine off the motor mounts, I could snug up the strap to help keep the engine level left to right.
    • projectJTv4
      • Sep 2019
      • 174
      That's a great idea! I'll definitely do that next time. Once the engine/trans, I understood why it kept wanting to rotate counterclockwise. Thanks!
      • projectJTv4
        • Sep 2019
        • 174
        I finally had a chance to pull some parts off of the car.
        Accelerator Pedal + connector and wires
        Fuel Pump Controller + connector and wires
        OBD2 Port + connector and wires
        CAS, JBE, Cruise Control
        Seat harness connector and wires. Useful for retrofitting E9x seats
        Brake Booster also pulled from my donor car.
        Intake Manifold + Harness pulled from another 330i at LKQ, pick your part.
        The last couple of things I want to pull are the driveshaft and brake calipers.
        Anything else worth salvaging before it gets towed away Friday morning?
        Last edited by projectJTv4; 02-23-2023, 09:52 PM. Reason: resized photos to 800 px wide
        • Panici
          • Dec 2009
          • 2574
          Engine is out! That's a big moment.
          Just in case you didn't know, the top arm of the engine hoist can adjust outwards. Usually makes things easier with it at full extension. Also a longer chain between the arm and load leveler.
          • hubcapboy
            • Oct 2017
            • 292
            definitely dig the fuel pump relay out because it's controlled by the ECU... other than that you'll need your throttle pedal, engine harness beyond the ECU...
            Don't shed tears over that connector. That's your water pump and it's the first "really this only lasts that long" item on these engines. They rarely go 100k, so if it's original to the car chances are you'd want to replace it during the swap anyway.
            • projectJTv4
              • Sep 2019
              • 174
              Thanks! My inexperience is definitely showing... haha. Lot's to learn, appreciate the advice!​
              Fuel pump relay... too bad all of the relays in the engine bay were removed. Did you mean the control unit for the fuel pump? I grabbed it based off of LukeJ's list.
              16147229173 - control unit for fuel pump, located behind rear passenger seat, pictured above
              35426858575 - accelerator pedal acquired
              I'll add water pump to the list of items to be ordered under maintenance, thanks!
              • hoveringuy
                • Dec 2005
                • 2751
                I don't know if you're planning on using all of the original EWS components (key, receiver, module..) or just flashing an EWS delete tune, but the EWS delete tune essentially turns the car into a Z4 which has a different CANBUS protocol than the E90's. E90 has D-CAN and E85 gas K-CAN, or something like that.
                Upshot is that it changes the CAN communications protocol so that the E90 EKP won't work anymore, you'll need an X3 or Z4 one. You can tell because they will have the "CAN11h" on them. The E90 OBD plug also won't work, you'll need add the wires for K-CAN.
                Also, that booster and manifold won't co-habitate in the same space.
                Click image for larger version  Name:	Capture.jpg Views:	0 Size:	96.3 KB ID:	10083144
                • projectJTv4
                  • Sep 2019
                  • 174
                  I initially did want to run all of the original EWS components, but it became quite cost prohibitive with this donor car. It did not come with keys, and I will leave it at that.
                  I do plan to just have the EWS delete tune.
                  Interesting note about the DCAN and KCAN. I'm fairly certain there is KCAN because I've seen diagrams and discussions for retrofitting seats. For my E92 and F32 seats, I bypassed the KCAN or whatever BUS by using a pulse generator to keep them awake. I'm hoping to keep the JBE just to see if I can get the memory function to work on the seats. But that's outside of the N52 swap.
                  Thank you for the picture reference, I'm planning on hitting another junk yard tomorrow. I'll see if they have any X3 or Z4's around and try to snag that fuel controller.
                  I'll look into a smaller booster to keep the manifold.
                  • projectJTv4
                    • Sep 2019
                    • 174
                    To follow up, I found a graphic showing the different communication protocols from this website: https://ohptools.com/blogs/news/whic...k-dcan-or-enet
                    My donor car/chassis/parts came from a 2006 330i, so I have K-LINE as the communication protocol, per graphic.
                    Not to be confused with the different bus systems
                    ACC - Active Cruise
                    AFS - Active Front Steering
                    DME - Digital Motor Electronics
                    DSC - Dynamic Stablity Control (Dynamische Stabilitats Control)
                    EGS - Electronic Transmission Control
                    EKP - Electric Fuel Pump (Elektrische Kraftstoffpumpe)
                    LDM - Longitudinal Dynamics Management zz0.6fla8ri3g32zz
                    • DEV0 E30
                      • Oct 2004
                      • 8904
                      Nice!
                      • projectJTv4
                        • Sep 2019
                        • 174
                        Wiring fun:
                        Accelerator Pedal Connector 61138383300
                        Color shifting wires for the accelerator pedal wiring.
                        Wiring Harness, Injection Valve / Ignition 12517566976
                        1 - oil pressure switch > 12618611273
                        2 - oil / coolant temperature sensor > 13621433076
                        3 - VANOS solenoid, exhaust > 11367585425
                        4 - valvetronic eccentric shaft sensor > 11377524879
                        5 - camshaft position sensor, exhaust > 13627525014
                        6 - VANOS solenoid, intake > 11367585425
                        7 - camshaft position sensor, intake > 13627525014
                        8 - air conditioning compressor > 64526956716
                        9 - thermostat > 11537549476
                        10 - coolant pump > 11517586925
                        11 - valvetronic eccentric shaft actuator > 11377548388
                        *ignition coils > 12138616153
                        *spark plugs > 12122158253
                        *fuel injector > 13537531634
                        Wiring Harness, Engine Module 12517563098
                        1 - crankshaft position sensor > 13627525015
                        2 - differential pressure sensor > 13628657300
                        3 - angle connector > 11618638014
                        4 - fuel tank ventilation valve with pipe > 13907618643
                        5 - throttle body > 13547516946
                        6 - hot-film air mass meter > 13627520519
                        7 - secondary oxygen sensor > 11787545074
                        8 - secondary oxygen sensor > 11787545075
                        9 - oil condition / level sensor > 12617607910
                        10 - alternator > 12317543083
                        11 -​ adjuster unit (disa 2, inner) > 11617560538​
                        12 - primary oxygen sensor > 11787558055
                        13 - primary oxygen sensor > 11787558073
                        14 - adjuster unit (disa 2, inner) > 11617560538
                        15 - ping sensor > 13627566785
                        16 - ping sensor​ > 13627566785
                        **starter connection goes to central box
                        mass air flow sensor > 13627520519
                        coolant temperature sensor > 13621433077 this is on a lower hose, next to radiator
                        DISA 1 ?
                        DISA 2 ?
                        throttle ?
                        crankcase breather valve ?
                        intake air temperature sensor ?
                        intake manifold pressure sensor ?
                        fuel tank vent valve ?
                        Most of the connections were already separated before me so I was not able to take any pictures before I fully removed the harness.
                        Can anyone help me figure out the items in red??
                        3/7/23 - updated the items in red, need to double check
                        13 - primary oxygen sensor > 11787558073​
                        *reverse light switch > 23147524811
                        Success in finding OEM exhaust manifolds with catalytic converters from a 2006 325i; 77 miles away in the middle of nowhere and about 1.5 hours to remove.
                        exhaust manifold with catalytic converters > 18407545308
                        exhaust manifold with catalytic converters > 18407545309
                        I don't know if its due to California's strict emissions, but the prices of these go for the same as a cheap N52...
                        Last edited by projectJTv4; 03-07-2023, 08:25 AM. Reason: updated harness information
                        • Panici
                          • Dec 2009
                          • 2574
                          What is up with those colour shifting wires?? Looks wack.
                          Is it just discolouration from oils? Did you try a solvent on them?
                          • Caperix
                            • Feb 2018
                            • 195
                            2 is the manifold pressure sensor in the intake, 5 is the throttle body, 4 is either the starter solenoid or the tank vent valve, 6 looks like the air mass, 3 & #11 should be the disa valves, 14 looks to be the crankcase vent heater, yours looks melted.
                            A e83 x3 coil harness will get you a single wire compressor clutch wire that should play better with the e30.
                            • LukeJ
                              • Jul 2019
                              • 139
                              If (#8) is a larger gauge white wire, the one that looks melted in the pictures. It goes to the starter solenoid.
                              The good thing about the wiring, is that they are all the right lengths to go to where they connect.
                              The other thing is every connector is different on each particular harness. There is only one connector that will fit the MAF for example.
                              (#2) is the intake manifold pressure sensor.
                              (#3) is the crankcase breather heater.
                              (#4) could be the fuel tank vent valve.
                              (#5) is the throttle body.
                              (#11) and (#14) are possibly the DISA wires.
                              • projectJTv4
                                • Sep 2019
                                • 174
                                Yeah... I tried solvent, no affect. It looks and feels as if a heat gun was too close to it, but unknown. I just have to keep in mind to to trace the pins and not rely on the colors for this one.
                                I may have to consider the e82 x3 coil harness you mention, we'll see how usable this harness is. I'm actually missing a connection one one of the DISA valves.
                                Thank you, all!
