Future of N52 Modifications and Performance
  • DEV0 E30
    • Oct 2004
    • 8897
    What does the future of the N52 hold?
    one take:
    Website:
    : https://22rpd.com/blog/the-future-of...esting-sign-up
    Facebook Group:
    All N52 enthusiast, owners, prospective and past are welcome. Please feel free to enquire for BMW business advertising. http://mywikimotors.com/n52b30/ N52B30. A home for the last naturally...
    I do recall multiple people talking about and wanting to go with velocity attacks or alternative intakes. What do you all see in the future?
  • hoveringuy
    • Dec 2005
    • 2744
    I did all of my initial turning with Zach at 22RPD. I also had a TB delete at first, but couldn't get it to be stable and found that the engine was much smoother with the TB.
    That's just a tuning thing, and Zach definitely has the chops to get it right. I don't see a huge difference beteen that intake and an N54 intake, the N54 flowed pretty damn well and I was pushing 275whp on his dyno with it. (He has an eddie curent dyno and although he swears it's been calibrated to match Dynojet, I think he's 5-8% high).
    N52 is a pretty great design and the finishing is first-rate, compared to something like the M54 which is still rough cast. Plus bedplate crank is happy with higher revs.
    There's lots of unexplored potential on the N52, for sure!
    adam.nonis , anything to add on intakes.
    • DEV0 E30
      • Oct 2004
      • 8897
      Good stuff.
      yeah I think my initial plan will be N54 intake to keep things simple.
      But very intrigued by future developments.
      • ome30
        • Jun 2022
        • 38
        Having owned a couple of N52 E90s, these engines just love being pushed hard. The are quite happy with a slightly spicier tune, a nice flowing exhaust and a the 3-stage/n54 intake.
        ITBs are something I never touched on because they're too pricey, also supercharger would be interesting.
        • digger
          • Nov 2005
          • 6190
          anyone do replacement cams yet?
          • hoveringuy
            • Dec 2005
            • 2744
            It's not quite the same on an N52, they have variable lift to start with and by changing the geometry it's easy to go from 9.9mm of lift to 10.5mm. See https://www.bimmermilvs.com/
            that doesn't take duration into account, obviously.
            Also looks like they are coming out with a custom exhaust cam.
            • digger
              • Nov 2005
              • 6190
              without the intake cam duration and more lift you're going to be limited in power. Is the reason that there is no intake cam available to date because of valvetronic?
              • FredK
                • 14762
                Well, the Schrick N52 cams from what I've seen have a shorter duration on the intake cam and a higher lift for both I/E. The specs are 238 / 10.6 mm and 272 / 10.5 mm exhaust. The lift for both stock and aftermarket cams are fairly conservative, which to me, suggests custom pistons and higher valve lift could benefit the engine a lot. What's interesting is the N52 intake cam is 34.2 mm with a 5 mm stem, whereas the S54 intake cam is 35mm with a 6 mm stem, so ostensibly the stock valves aren't going to be the pinch point for power.
                • digger
                  • Nov 2005
                  • 6190
                  Schrick dont have them on their catalog? and only seen them advertised by VAC (lol) im guessing 238/272 is a typo
                  • FredK
                    • 14762
                    yeah lol that's where I got the spec from. so who knows lol. What could the typo be? 338? lol
                    • digger
                      • Nov 2005
                      • 6190
                      268/272 would be my guess. From what i read catcams didnt want to develop a N52 cam(s) and the schrick ones seem to be non existant or a typo but who knows tbh.
                      IIRC i did read that people removed the valvetronic and then could use N54 cams? if you are building a high performance engine the valvetronic probably isnt heping you much. But in the end i guess you need to work out the end goals and how much the N52 is going to look like a lighter but less powerful s54.
                      • hoveringuy
                        • Dec 2005
                        • 2744
                        That's the point of the MILV kit, it changes the rocker ratio to increase lift.
                        The cool thing about Valvetronic is that there's less lift at lower rpm's so you still maintain velocity (and torque)
                        • hoveringuy
                          • Dec 2005
                          • 2744
                          Bingo. A proper S54 swap is running 15 large. I weigh 100lbs (?) less and still make 250 to the wheels with a nice broad torque curve, in a motor that came out of a soccer mom car.
                          I feel like I could make an additional 50hp and be only slightly faster around the track as it is.
                          I even bought a low-mile spare a few months ago for $500 and that motor was pristine.
                          • FredK
                            • 14762
                            I think the N52 can support some real revs due to its robust bottom end. The real beauty of the N52 is that it's newer than any S5x engine, is lightweight, and is unbelievably affordable to replace.
                            • hoveringuy
                              • Dec 2005
                              • 2744
                              Compare the valvetrain and rev limit of the S55 to the N52, lemme know what you find...
                              also, the mechanical damping properties of magnesium vs steel (and aluminum..)
