N52 Swap Discussion
  • Nizzan
    • Feb 2025
    • 6
    #841
    Thanks Caperix…Yes, I modified the Datsun front crossmember to accommodate the stock e92 motor mounts, then fabricated steel supports on the N52 block side to position the engine properly and isolated them with 1/16” aluminum against the magnesium.
    Very familiar with HybridZ, and will share my progress once I have a bit more to show….Gotta get the lions share of the electrics sorted and the car rolling under its own power, then do a nice summary of the work.
    • hoveringuy
      • Dec 2005
      • 2754
      #842
      Yee-haw!
      • benz-tech
        • Jan 2011
        • 382
        #843
        How are you guys installing the engine. I don’t have a load leveler for engine/trans package might be a challenge to drop in, although I can prob borrow one. How do you do it?
        You say "Where are your other two cylinders?"
        I say "Where's your other camshaft?"
        Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
        • hoveringuy
          • Dec 2005
          • 2754
          #844
          I prefer from the bottom. I attach the front subframe under the engine a lift it up.
          • benz-tech
            • Jan 2011
            • 382
            #845
            Yeah I would prefer that also. But I don’t have a lift at home and I’m pretty sure my jack stands don’t go that high
            • hoveringuy
              • Dec 2005
              • 2754
              #846
              I don't have a lift, either. The body is jacked-up in stages and supported on the frame rails high enough to roll the engine assembly under the core support. Then the body is lowered onto the engine (while it's jacked-up a bit as necessary).
              I've done this single-handed a few times and it's easy.
Name:	Screenshot 2026-08-30 092935.jpg
ID:	10166159 Click image for larger version
Name:	Screenshot 2026-08-30 092835.jpg
ID:	10166160 Click image for larger version
Name:	Screenshot 2026-08-30 093020.jpg
