Changing your fluids! (diy)
  • furwolf
    • Sep 2009
    • 71
    Nah, you didn't, I forgot that part. I just know they're torx and they're big. I can try and check later if you really need me to.
    -FW
    • EA8
      • 328
      never mind ... 17mm for transmission & 10mm for rear diff (guess a little research does help :D). I just drained my diff and when I went to pump the fluid in, the pump had a leak in it so it squirted all over the place. so I have to wait till someone gives me a ride to get it replaced (NAPA). Any suggestions on taking the fill plug off of the tranny? The only 17mm hex I could find was a large L shaped beast and I am having a hell of a time trying to loosen it.
      • bimmer95
        • Oct 2009
        • 30
        Cut off about an inch of that 17mm allen wrench and use Automotive Goop to glue it in to a 6-point 17mm socket.
        • EA8
          • 328
          that's what the mechanics were telling me, but I was hoping there was another way to do it ... damn you ... :D
            • 34839
            there is, buy a 17mm hex socket.
            • EA8
              • 328
              thanks nando .. now i feel like an idiot
              cheers ...
              • furwolf
                • Sep 2009
                • 71
                Yeah Nando, damn you and your logic
                Man I love the smileys on this board.... :)
                -FW
                • bimmer95
                  • Oct 2009
                  • 30
                  Sure, if you want to take the easy way out ;) However, a good 17mm hex socket is ~$20 versus ~$3 for a decent 6-point socket, if you already have the 17mm allen. Plus you can made the bit length exactly what you want it to be, though that's more of an issue with 14mm hex sockets for diff plugs.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    You could also take a 17mm bolt with 2 nuts on it, put it in there backwards and out she comes. Even cheaper, and more redneck.
                    Originally posted by Andy.B
                    I was born on 3/25…
