Should I just pull engine/trans together as one?
  • A Sucked Orange
    • 707
    So I am looking at replacing the following:
    Head gasket
    cam seal
    crank seal
    rear main seal
    timing belt
    clutch
    transfer case VC
    right front axle
    control arms
    I guess my options are:
    1) drop t-case alone, pull engine & tranny...
    2) leave engine in, drop t-case, drop tranny...
  • Dj Buttchug
    • Jun 2010
    • 7686
    jus pull it. makes it way easier imo
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • A Sucked Orange
      • 707
      Thanks.
      Will just drop everything on to dolly's and lift the car with a hoist.
      • nomansland92
        • 1657
        ya i'd drop it.
        IX being restored here
        Ix turbo build here
        • cozdzy
          • Apr 2011
          • 6
          is it easier than lifting, since I want to replace the motor?
          • A Sucked Orange
            • 707
            Ive done several engine pulls both ways and I am pretty much sold on the pull everything technique. It makes everything way easier... This time it'll be a drop though, since I dont have overhead room. I suspect it wont be too hard.
            • Kershaw
              • 11822
              let me know how it goes.
              AWD > RWD
              • MattM
                • Apr 2009
                • 931
                im curious as to how this went as well, im going to be pulling an IX drivetrain in the next week.
                Full Build Thread Here
                • A Sucked Orange
                  • 707
                  Went spectacularly easy. I might never pull anything up through the bay again.
                  Once I had everything prepared it took me about 10 minutes to have the whole drivetrain out and beside the car.
                  • MattM
                    • Apr 2009
                    • 931
                    awesome, sounds like ill be giving this a shot, ive done lots out the top, but the added weight and difficulty of the front drive has me a little anxious to be suspending it above the body...
                    • tirefryer
                      • 106
                      how high did you have to lift the front end of the car to pull the drivetrain out from under the car?
                      • A Sucked Orange
                        • 707
                        However tall the engine is minus the manifold. I did it in a low garage.
                        • LuckyHenriksen
                          • Jun 2010
                          • 4244
                          That is how I pull all engine/trans combos. Especially nice when you are working with the added length/weight of the transfer case
                          Bahama Beige E23 Project
                          Bluebird Bus Conversion
                          New Oregon Trail
