What Lowering springs shouls I use?
    • 34839
    Originally posted by devon.818
    vogtlands and billy sports
    i ordered drop hats, haven't installed those yet.
    these springs are the shit! my buddy has GC's, yeah his sits lower, but mine FEELS better, both our opinions. few people have said that the vogtlands are the best if you daily your car, mild autoX....which i do, couldn't be happier.
    this is an ix thread - and drop hats don't work on ix's. neither would vogtlands..
    • mbulsa
      • Oct 2009
      • 313
      I have the h&r/bilstein set up right now and there is a big difference. Its a lot lower than with stock springs but its not too low that it'll put a ton of pressure and wear out the axels
      • saurey
        • Oct 2012
        • 71
        Old thread I know...
        My 2c. I prefer the higher stance of the stock springs aesthetically and functionally on the IX. It makes the car look capable and sporty to me and you'll ultimately have more clearance in the snow/mud if you actually use it for that. I was thinking for a minute of getting the HR Sport springs but decided against. If I want a low e30, then I'd do it and I'd get an s52 swapped one.
        • Wille30
          • Sep 2012
          • 89
          I'm not sure what springs I have in my car. I have Koni's up front and Bilstein in the back. I can't find any markings but the springs feel very stiff. The car came from Germany so there may be different aftermarket options there. The distance from the center of my front hub to the fender is 14.5". Is that stock height?
            • 34839
            That sounds stock, im less than 12" from hub center to the fender iirc.
            • Wille30
              • Sep 2012
              • 89
              I would love to be in that range, but will H&R ix sport get me there?
                • 34839
                No.. and not with stock strut housings either
                • Wille30
                  • Sep 2012
                  • 89
                  See, I'm in a dilemma right now as to whether I should switch out my springs (not sure of where they came from, but they feel fairly stiff) and put in H&R, and quite possibly have very little difference or spend a little extra and go for the GC kit. Sorry to jack the thread a little.
                    • 34839
                    You need modified struts and shorter inserts for gc to be worth it. Otherwise there's not enough travel.
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      Originally posted by Conster
                      H&R sports is the best option; used KONI sports to complete my set-up.
                      Im rocking bilstein/h&r set up and my front end gap is bigger then the rear. Your KONI sports set up with the H&R sports got you the smaller gap up front?? I like the way your car sits.
                      '91 318i (Alpine) - daily
                      '88 325ix (Zinno) - drive here and there!
                      • Wille30
                        • Sep 2012
                        • 89
                        So I guess I am little higher eh? I guess that 1.3"
                          • 34839
                          That looks stock
                          Nice touring :)
                          • saurey
                            • Oct 2012
                            • 71
                            It looks stock and great. Also Touring FTW!
                            • purpletrees
                              • Dec 2012
                              • 83
                              Does anyone know if bilstein sport shocks fit in the rear? I'm running HD's with H&R right now.
                                • 34839
                                yes all E30 rear shocks are the same
                                but there's really no point in switching unless your HDs are worn out
