RWD - handling
  • kristov
    • 222
    RWD - handling
    Will an RWD conversion affect the handling of the ix much?
  • kronus
    • Apr 2008
    • 13020
    but.. why would you... do that?
    The front struts are angled completely differently than on fwd cars, it'll understeer like a pig.
    cars beep boop
    • mr2peak
      • 2388
      Sell your IX then buy a clean iS. A RWD IX is going to be tough to sell when that comes up
      Drive it hard. Maintain it well.
      A Topless Memorandum
      • kristov
        • 222
        So making it an RWD will make it understeer - why?
        The car is road legal with a turbo engine.
        • Kershaw
          • 11822
          why the hell would you do that?
          there is no good reason.
          AWD > RWD
            • 34827
            yes. it will handle like ass. Ask Ryan M3.
            • kristov
              • 222
              So if I retain the AWD the car will not handle like ass?
              Could someone please explain the physics behind this?
              The reason I am considering this is because there is noe current solution to make the front diff more durable when running high hp's.
                • 34827
                the suspension geometry is not set up for only RWD. Much less caster, different scrub radius, different track width, etc. etc. etc.
                Ryan had an ix in his shop that somebody had removed the AWD and put an S52 in. It was so bad, that they removed the S52 and returned the car back to stock.
                • downforce22
                  • Aug 2009
                  • 3191
                  take care of the diff it can handle moderate power, going for high horsepower, buy an e, i, or is
                    • 34827
                    there's always an E34 or E46 diff
                    • kristov
                      • 222
                      What would be required to use such a diff?
