Here is the back wheel 16x7.5 et35 with 225s. I've thought about putting 10mm spacers I have on the back, but it didn't like the idea of having the back wider than the front, even if it made it flush. The back is probably narrower for a reason. My car isn't as low as nando's or kershaws so you can't see how much space there is as well, but you can get an idea.
Here is a pic of the front and back. Ignore the huge nasty wheel gap, I will be fixing this hopefully soon when I get some money for gc. Notice that the back is set in quite a bit further than the front.
I didn't have to use a spacer at all on the front the clear the caliper with et35, so you should be fine. I'm pretty sure I'm not rubbing, but I didn't really check specifically to see if I was.
