Any ixperiences without power steering?
  • TOAST
    • Jan 2006
    • 316
    anyone care to comment about running their iX without power steering?
    i need to r&r top to bottom fixing the leaks but thought id save a buck and run without the power steering kit.
    thoughts?
    • 34844
    Yeah, it sucks.
    • Kershaw
      • 11822
      with 195 snow tires it's a lot easier than 205 summer tires.
      it sucks regardless. gl parallel parking.
      AWD > RWD
      • flyboyx
        • 8371
        Originally posted by nando
        Yeah, it sucks.
        please allow me to expand on this a little: it sucks sweaty hairy swamp ass.
        we drove my son's car back from charleston with a bad ps hose. trying to parallel park was beyond terrible. any sort of front back maneuvering was almost unmanagable. just fix your system and be happy. certainly would not be worth the weight savings unless your arms were transplanted from a gorilla.
        Gigitty Gigitty!!!!
        • ttrousdell
          • Nov 2009
          • 1770
          Look at the positives. no need to go to the gym now.
          The Build:
          • nrubenstein
            • 3148
            The iX is undrivable without PS. It's worse on all season tires than a RWD E30 on r-tires.
            Had to cut the belt one time way back when and it was really bad around town.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • Stevo-iX
              • Jul 2010
              • 231
              It IS drivable. I do it every day. Gladly. And on 8" wide all the way around.
              Delete power steering properly and it should work well. Best of luck.
                • 34844
                8" wide wheels, or 8" wide tires?
                my old tires are 10" wide. trust me, it sucks.
                • FLG
                  • Sep 2011
                  • 3165
                  EXACTLY!
                  Running a PS car without properly deleting the power steering is much like removing the vac line from the brake booster and than saying that manual brakes suck.
                  Your fighting the pump, and the fluid. If you want an idea of how it will feel, remove the belt from the pump and remove the lines, leave everything open for now (you will loose fluid so make sure its not all over your driveway) and see how you like it..if you do buy the kit that a fellow r3v'er sells which loops the 2 holes using an aluminum plate..this allows air and fluid in the rack to be moved while turning the wheels, while also keeping debris out.
                  It also depends on your living situation, me being in NYC without a ps steering will probably get old fast...but if i lived in a more open area where its highway driving and minimal parallel parking..id probably enjoy it.
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • 34844
                    we're talking about the ix here. it's a totally different animal - it doesn't have the lightweight/non-existant steering feel with PS that the RWD E30s have.
                    you're also fighting the torque being transmitted through the front wheels, and the wider track.
                    • bcausey
                      • Jan 2010
                      • 316
                      It definitely depends on you and the drivability you desire.
                      Mine is currently inop but I drive in the mountains mostly.
                      Save up - buy the kit and fix it. Keep driving. Done.
                      • 325ix
                        • Aug 2009
                        • 7783
                        Hmm. I had no trouble with no PS and I am a skinny little kid.
                        • Ether-D
                          • Sep 2011
                          • 2838
                          I have no power steering in my iX. It sucks and I'm a big beefy adult.
                          It's doable for a bit, but you'll want it back.
                          Originally posted by Andy.B
                          I was born on 3/25…
                          • psmura
                            • Mar 2012
                            • 119
                            Pull the powersteering belt off and give it a shot. It seriously isn't that bad at all. I expected it to be much harder to turn the wheel but it wasn't. I don't know what others are talking about.
                            I think you actually get more feel for the road. Parallel parking on the other hand is a bit of a different story.
                            1989 325ix
                            1992 325ic 770A
                            2002 M3
