iX Trunk Carpet?
  • lambo
    Captain Scene Points
    • 10953
    iX Trunk Carpet?
    Is the trunk carpet in an iX, iX specific?
    I realize the shock mounts are probably in a different location versus a rwd E30...
    Thanks!
    • 34844
    actually, AFAIK, it's exactly the same. there's no diference in shock mounts for certain.
    you could always cross reference part #'s on realoem.com and see.
    • downforce22
      • Aug 2009
      • 3193
      i think the only differences are the front struts, suspension components, awd components and transfer case/transmission/oilpan etc. i envisioned the rear of the car from the driveshaft back to be the same. i think the rear swaybar is bigger iirc
        • 34844
        there are some differences in the rear of the car but they're fairly minor.
        • flyboyx
          • 8371
          all of my ix's came with a piece of carpet under the carpet instead of that 1/2" of tar that would otherwise be under the mat in a coupe. so i think the top mat is the same but the under mat is ix specific.
          Gigitty Gigitty!!!!
          • 325ixa
            • Jun 2011
            • 73
            under mat is for cars with bbs 5th(spare) alloy wheel.
              • 34844
              yeah, the RWD cars came with 195s on a 14x6.5, I don't think a 205 on a 15x7 would have fit in the spare tire well otherwise.
              and yes, my ix doesn't have trunk tar. however, my '88 did (and a lot of it!). they also came with a heavy as @#$^ spare tire with a 14" steel wheel..
              • lambo
                • 10953
                Yepp, the carpet isn't iX specific. I don't know why I didn't think to check realOEM... Must have just been user error that caused it not to fit properly...
                Thanks guys!
                • 325ixa
                  • Jun 2011
                  • 73
                  if you turn it upside down, it does not fit :)
                  • nomansland92
                    • 1657
                    my 88ix has trunk tar, well it did but not after i got my air chisel :) and the rear disk brakes are different but the fronts are the same as a rwd. I know the rear bushings are different as well and i can't remember if it was the rear sub frame or the trailing arm but one of them is IX specif.
                    the trunk carpet should be the same though.
                    IX being restored here
                    Ix turbo build here
                    • 325ixa
                      • Jun 2011
                      • 73
                      hm, tar...
                      i was talking about this, not tar.
                        • 34844
                        yeah, my '91 has that mat thing. the earlier ix's just had a big old 1/2" thick slab of tar.
                        I never realized that under-mat was ix-specific though..
                        • 325ixa
                          • Jun 2011
                          • 73
                          ive seen it on cabrios and normal e30 and they all had spare alloy wheel, factory fitted.
