apparently i have a 325ex
  • Kershaw
    • 11822
    #31
    ^ this. that's why the more you change your injectors, the more your obc is off. i have a friend with an m30 swap and the obc says he gets 25-30mpg. lol he gets 15-18mpg.
    i have 17.5lb injectors (stock being 14.5) so it's not a huge difference, but it is off.
    AWD > RWD
      • 34844
      #32
      you measured that over 1 gallon, which you couldn't possibly know accurately, plus the OBC said 30mpg which we know is way off (more things affect the total % difference other than pure size, reaction time has a big effect). "not a huge difference" is really 3-4mpg, enough to explain your anomaly (I once got a *real* 26.5mpg in my ix when it was bone stock and automatic).
      • 325ixa
        • Jun 2011
        • 73
        #33
        Originally posted by nando
        no it doesn't.
        it reads an injector PW signal which it can translate into fuel volume. it knows how far you're going from the VSS input, so it's simply distance traveled/fuel volume = mpg.
        did some research and you are right. Dont know where i got that ecu measures air flow and calculates consumption based on that.
        injector puls, revs and speed in equasion gives consumption on obc.
          • 34844
          #34
          well, the econometer can be related approximately to engine load, which is related to airflow. old VW's used a MAP signal to do nearly the same thing as BMW, it's just not quite as accurate because it doesn't know the true mass of air or fuel.
          • Isostar13
            • Nov 2011
            • 288
            #35
            Tire size? If you change too far from stock your speed and mileage will register differently, which could explain the higher reading.
            I average about 20 city, maybe 22-24 highway if I absolutely baby it. I'm on stock 205/55/15 tires, with a stock m20 (no chip.)
            1988 325ix
              • 34844
              #36
              he has larger than stock injectors.
              /end
              • Bretts85E30
                • 340
                #37
                Man as an eta I feel ashamed by the fact that I'm gettin the same mph as an ix at 23mpg it sucks
                • Kershaw
                  • 11822
                  #38
                  my tire size is smaller than stock. i run 205/50/15s. i think stock is 205/55 iirc.
                  with an eta, you can run the piss out of it and still get 30mpg. if you're getting 23mpg, you need to change your o2 sensor and go from there.
                  AWD > RWD
                  • Bretts85E30
                    • 340
                    #39
                    did that and my injectors and gas mileage shot up from 17-20mpg and that was a year and a half ago..... my thinking is its probably my afm
                    and stock tire size is like 195/65R14H
                    • Kershaw
                      • 11822
                      #40
                      not for an ix.
                      AWD > RWD
