Be aware of in front of clutch change?
  • Kvasi
    • Apr 2011
    • 1122
    So, my stock clutch is slipping on full boost from 3. gear and up, and i have got good deal on a stronger set from Sachs.
    But damn im not looking forward to the job changing it, anything i should be aware of before i start?
    A DIY would be awsome.
  • downforce22
    • Aug 2009
    • 3192
    Which method are you doing? Dropping the front subframe with the engine out from under the car or removing the engine out the front of the car and leaving the tranny in the car?
    • Kvasi
      • Apr 2011
      • 1122
      The plan is to drop the transmission, but im open for ideas that will make it easyer/faster.
      • flyboyx
        • 8371
        just drop the trans. its not easy to get to the bolts on top of the bell housing but it can be done.
        Gigitty Gigitty!!!!
        • travish325
          • Jun 2012
          • 1151
          it seems alot harder than it is. If you get the car jacked up high enough that will make things very easy. Ive done it twice by myself with but I recommend getting help from someone
          • packratbimmer
            • Dec 2009
            • 1334
            Minor tip: If you have a couple of pedal cluster bolts around, use them as guide pins for the subframe and the you can lower the whole assembly 1-3 inches for access.
            • nrubenstein
              • 3148
              On a rear drive car, you can swap (IIRC) the rear subframe bolts to the front holes and get the subframe down about an inch. I expect that the same applies to the iX, but check the bolt lengths on RealOEM.
              You should be able to get to all of the bolts using extensions and a wobble bar.
              On an iX, make sure you buy all of the shifter components for a rebuild - you can't get to them with the transfer case installed, so it's pretty dumb not to refresh everything while you are in there. :)
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
