Switch to 173 DME from 153
  • moto650
    • May 2011
    • 155
    I have squirreled a gray label 173 DME. My 1988 325IX currently has a green label 153 DME.
    From my research the PRO would be: Stomp Test as per this while the CON is potentially (unverified?) worse fuel milage. Additionally, there's no apparent compatibility issue and a IX DME is the same as non-IX as per this
    I like the idea of "the latest and greatest DME" because in my mind there'd be no newer if the old was as good as it gets.
    I don't really see a reason to not do the swap however, I thought I'd ping the group and make sure I'm not missing something obvious (Possible, I can be shortsighted).
    If it matters:
    The 173 is unmolested OEM, pulled from a standard E30.
    I have light green top, 4 pintle 17lb injectors.
    All warning lights are currently OFF on the dash.
    Go for it :up:
    Or whiskey tango; don't fix what not broke :down:
    88 325ix, 72 Type 1, 81 Starlet
    • 34844
    If it matters:
    Go for it :up:
    should be no problem, except potentially you'll need to add a 1k resistor to pin 17 of the C101 connector (early ix ABS systems sometimes had issues with the ABS communcation to the DME, there was a recall repair that was basically the same thing for cars with the 153 DME).
    as you know, there's no such thing as an ix-DME. swapping it should take maybe 15 minutes, just give it a try. if the ABS light comes on then add the resistor.
    • moto650
      • May 2011
      • 155
      Yes, pull signal a little harder to GND. If it comes on, I'll do that; thanks.
      • bmwguy325is
        • May 2011
        • 1263
        I have done this had no issues.
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • nomansland92
          • 1657
          i did the same this with my 88' no issues. Can't say anything for the abs casue mines never been connected
          IX being restored here
          Ix turbo build here
