So I made a second round of these spline extension as requested. Price is 250euros including shipping worldwide. If you want to use paypal, that will add 20euros more.
pm me if you are interested.
Quoting old text:
Hi guys!
I started to uppgrade my ix drivetrain and first thing is front shaft splines.. I have reade that they are the first point where it cracks.. here is couple articles that i read
i teared my ix transfer case apart and took measuments
front shaft splines are on top of each other only about 18-20mm and there is 60mm long splines in gear sprocket..
so..
Heres what i got
im making new weld-able splines to my front shaft..
...increasing spline "neck" of the shaft so that splines start from the same mark than spline touching each other... also i make splines 50mm long in the shaft... so touching are increases x2.. head is made of imacro M steel and it has section that will be pressed into old shaft pipe, making it stiff and help welding..
so if someone is interested purchasing this part, i will make it and post it with instructions...
Quoting old text:
Hi guys!
so..
Heres what i got
