Need some brake/rotors and exhaust advice
  • anonymous alias
    • Jun 2013
    • 66
    Originally posted by nando
    what kind of power do you have?
    do you track the car? if not there's not really going to be much point, other than costing a lot of money - also your e-brake won't work any longer if you use a RWD brake kit.
    one benefit would be lighter unsprung mass. I don't know if anyone makes an ix-specific rear brake kit - I doubt it. it might make more sense to swap to a RWD trailing arm, but then you're going to be forced to use a spacer to make up the difference.
    if I were you, I'd just replace everything with new stock parts and use an aggressive pad instead. if you want to get crazy order rear disks from an ix touring, they're vented.
    No I don't track the car. It's my dd but I would like to track it from time to time. But I see ur point. I need to replace my brakes n rotors all around not just the rear. Was looking for something a bit more "sportish" than stock. But I guess I could just paint the calipers lol. What pads would u suggest? Iirc ur using ATE?
      • 34830
      just replace it with all new stock parts. those look pretty wasted, so just a refresh will probably seem pretty sporting.
      I have pagids with ATE powerdisks. nothing special - but it works very well.
      if you want to do a track day, use different pads/rotors for that - it saves you from wasting your street brakes, and not having to deal with the extra noise and dust of track pads on the street.
      • anonymous alias
        • Jun 2013
        • 66
        thats a good idea. i just want something that works well for the most part
        • Cletonius
          • 2809
          Originally posted by jute91
          Well this is little bigger swap.
          Only hub+rotor swap gives you 283mm rotors.
          Here is mine.
          With e87 hub you are able to use low offset rims at the back( I'm running 10x17 et 15) For the front it just make track little wider ( have try to think some other options for it but this will do the job for a while)
          What I am going to do is that fitting front disc to rear rotors hub so i could get thicker rotor + still working hand brake. Then Im going to move front calipers to rear axle ( Wider pads) and fitting the e32 calipers ( 4-piston and light) to front. Of course when your calipers have now more pistons you need to uppgrade your master cylinder. e30 ix has 20mm master cylinder when e32 has 25mm ( will bolt on)
          That's pretty slick. Not a bad way to go 5 lug and keep the stock geometry
          - Josh
          1990 325is
          Need a shift boot?
          Looking to buy shift boot frames, PM if you have one to sell
          Here's what happens when you let the internet pick your license plate
          • anonymous alias
            • Jun 2013
            • 66
            Here is mine.
            What size tires are u running? any more pics of ur car?
            • jute91
              • Nov 2011
              • 581
              Tyres are 215/40 at the front and 245/35 at the rear
              My build thread @ http://www.r3vlimited.com/board/showthread.php?t=276989
              Also found on Facebook - Juuso Tero, Tampere
              https://www.facebook.com/JuusosGarage
