They seem to last a long time, mine have 80,000 miles and are just as tight as the new ones i got for mockup.
24V AWD Swap Knowledge Base
This is a sticky topic.
My Garage
Feedback
Instagram: Stone.HopkinsComment
no, it came with 3.38, and only 3.38. :(
on the E46 rack - curiousity finally got to me, so I removed the E46 tie rods and mounted the E30 ix tie rods on the E46 xi rack.
edit: retracted
the grommet that holds the boot on my driver's tie rod had moved, making it look like I had another inch, when in fact I did not.
basically, the E30 ix tie rods are 1" too long. the E46 tie rods are actually the right length, but you'd have to machine the strut housings to fit the larger ball joints, and I don't really know how feasible that is. the ball joints do not unfortunately press out.
the E46 outter tie rods are too short to work with the E30 inners. perhaps there exists an outter tie rod that is 1" shorter than the E30 ix, has similar geometry, and has the right ball joint.
the two options are basically:
1. use E46 xi tie rods as-is. machine the struts to fit larger ball joints. this seems most realistic to me - there appears to be enough material left. about 2mm would have to be taken out. the E30 ball joint is about 13.5-12.2mm taper, the E46 is about 15.5-14.5mm taper. the threads on the E46 are longer but the part that goes through the ball joint is approximately the same length.
2. find some magic outter tie rod that threads onto the E30 ix inner and has the right ball joint. it needs to be about 1" shorter than the E30 tie rod.
I'll have to take it to some machine shops and see what they say. I have an extra set of strut housings I can take with me.Last edited by nando; 01-10-2015, 11:08 AM.Comment
My Garage
Feedback
I bet its about the same, only the x5 is larger, so it might be too wide. The E46 tie rods are already the right length (i might trim some threads, but there's lots to work with).
As a side benefit, i can have the ABS sensor holes modified to use my E46 M3 mk3 DSC unit.. :)
Yeah, at ride height. It doesn't change much at that end thankfully due to the length of the shaft.Comment
The length of the rack, from one INNER tie rod pivot to the other inner tie rod pivot is important for getting bump steer right (or at least keeping it the same as BMW did).
edit: retracted
That's an important dimension that needs to be addressed.
Also, aren't the iX tie rod ends the weird shape they are for wheel clearance?Comment
Looks like both X5, E34ix and E46xi rack mounts the same, behind the "subframe" and not on top like the E30ix.E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
E30 M50 6 spd 764whp @ 24psi.
E30 M20 6 spd 675whp.Comment
E46 tie rods are really close to the same shape as the E30 - they're just a bit shorter. They have the same funky bend.Comment
