24V AWD Swap Knowledge Base
This is a sticky topic.
    • 34834
    #646
    Only if they are fully tensioned. And there is a specific surface prep for that. Otherwise, they are in shear and/or tension. You could argue the trans bolts are in both, but there is neither a surface prep or fully tensioned specification for the trans bolts. They would be a TTY bolt otherwise.
    I've designed a lot of bolted connections..
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #647
      And I've worked in aerospace, home of ultra-light structures, bolted joint nerdgasms and carbon faced honeycomb structures.
      Are you saying that a bolted joint doesn't work the way it's supposed to if the bolts are not torqued to the design value? Umm... newsflash... ;)
      Calculate the torque preload on a bolt at even a modest torque value like 15 ftlbs, and analyze the beam stress in the powertrain at the engine/transmission interface and you'll find that the preload is FAR *FAR* greater than the tension from the beam loading. IOW, the integrity of the transmission to oil pan joint depends on the *STATIC FRICTION* of the interface, NOT the shear strength of the bolt. OBTW, the static coefficient of friction for aluminum on aluminum is ~8, so friction is kind of a big deal.
      If you're referring to machining the bolt seating surface to ensure circumferential contact... that's why we use washers. Yes, I am aware that aluminum would creep under the high contact stress of point loading and drag from tightening a bolt on an as-cast surface.
        • 34834
        #648
        I'm actually not talking about that. I mostly work with steel. a lot different than aluminum/aerospace.
        anyway, the lower half of an N52 block came in. the part that holds all the bearings is about 15lbs. I wonder what the rest of the block weighs? I'm also trying to figure out if the lower part of the block is all magnesium or aluminum. It has embedded steel inserts for the actual bearings to sit into, and I believe the bolts that thread into it from the transmission are steel. So I'm thinking it's aluminum.
          • 34834
          #649
          Here are some pictures of the ix oil pan on the bottom of an N52 block. You can see how much different the N series motors are from the M series. However, having this lower block for mock up is soooo much easier than the S52 block I had to drag around before! that thing was like at least 100lbs, what a pain in the ass!
          The N52 block is about an inch longer but that includes the timing cover so it's not a 1:1 comparison.
          all I need is a front diff and I can start cutting. I also need to find somebody who can weld it back together..
          also, the design of the N52 with the lower main caps being part of this whole assembly means it's really stiff. the stock N52 redline is 7k (compared to an M54 that will shake itself to pieces above 6k realistically). I'm thinking a 10% increase would be realatively feasible, to 7700rpm. Also, MSV70 was actually designed to run without a MAF - but they left it in for emissions reasons, basically. I intend to run it without a MAF as it was originally designed (it uses widebands and an advanced model to run the engine instead). I'll probably start with the 3 stage manifold and work on my own manifold in the future, with a CF airbox. Having no throttles makes things a lot easier...
          The head design is also similar to the S54 (same finger/lifter design, but with hydraulics instead of shims and of course VVL). It has smaller ports, valves, and a less aggressive cam, so it's not going to make power at 8500rpm, but there's definitely a lot of potential. Similar to the S54, the intake ports are CNC'd from the factory. I'm looking for about 300bhp, and considering I put down 232whp on a cold day basically stock in my 330i, I think that is achievable with headers, cams, and tuning.
            • Jun 2010
            • 2796
            #650
            Die cast? Nice piece. Tooling marks from the die are visible in that last shot.
            I haven't looked at how to tell aluminum and magnesium apart other than density. The steel bearing insert sounds like a clincher, though. Nissan does the same thing in the VR38's bedplate in the GT-R.
              • 34834
              #651
              I'm pretty sure it's magnesium. I scuffed a corner of it and it looked a lot different from fresh aluminum.
              don't catch it on fire, huh? :p
                • Jun 2010
                • 2796
                #652
                Or do...? :p that would be fun.
                Do any of the bolt holes line up? Going to get an E70 X5 oil pan to hack up and weld in the E30 diff mount?
                  • 34834
                  #653
                  no.. none. not even one hole. also, the N52 block is a little deeper, by about 1/2". I put the E34 pan on it for the heck of it. So even that wouldn't fit.
                  but yeah, that's the idea. Need to find a fabricator who can work some magic, as there are some issues. Need to find a front diff first so I can have a full mock up.
                  Here's the rest of the pics I took yesterday. E30 pan placed approximately in line with the driveshaft (it's at the wrong angle, obviously):
                  here's the E70 pan. The rear bolt mounting bosses for the pan interfere with the driveshaft and where the flex disc would go. obviously, on the later cars the diff is further to the drivers side, while the E30 is much closer to the center. So much of this rear area will need cut apart. Fortunately I think I can still bolt it down, there's a second flange where it actually seals that could be used. the driveshaft also touches the rear of the sump, it's actually pushed a bit further into the transfercase than it would normally be:
                  • King Mufasa
                    • Sep 2012
                    • 530
                    #654
                    What did you use to clean those parts? Looks very clean!
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #655
                      Really cool man, looking forward to see where this goes!!
                      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                      E30 M50 6 spd 764whp @ 24psi.
                      E30 M20 6 spd 675whp.
                        • 34834
                        #656
                        The transfercase is new, the trans was rebuilt by drivegear.com a year ago.
                          • Jun 2010
                          • 2796
                          #657
                          And has only been touched three times since then ;)
                            • 34834
                            #658
                            Basically. Lol.
                            But it will be like a new car when complete. :)
                              • Jun 2010
                              • 2796
                              #659
                              I'd like a rebuilt transmission... you're a baller ;)
                              I'd love to build an M73 (or maybe M70B54 frankenmotor) E34 with Getrag 265 manual trans. A Metric Mechanic rebuild for that, especially with the billet internal shift linkage components, would be great, but that costs as much as the 560G six speed for the V12... :-?
                                • 34834
                                #660
                                Yeah well, that's the paradox right? I used to have unlimited time and no money. Now, money isn't necessarily unlimited, but i don't have free time.
                                I'dlike to aactually accomplish something this year though. I've been working on it for 4 years and all i have so far is a bunch of parts! I'm thinking I'd like to get the mk60 dsc system retrofitted this year.
