24V AWD Swap Knowledge Base
This is a sticky topic.
  • The Dark Side of Will
    • Jun 2010
    • 2796
    I originally posted this on E30Tech. When I first started my 32V swap project, it looked like E30Tech had a better AWD section, while R3V had a better 32V swap section. That appears to have changed.
    Original thread: http://www.e30tech.com/forum/showthread.php?t=116657
    I've been reading up and doing a lot of RealOEM research related to my 32V AWD swap. I'll be coming back to this post to complete it and add more information.
    I've come across several 24V swaps that are in the works, but only one, IIRC, that has been completed.
    Some of the information in this post is from my own research, much of it is from information I've read here on the forum and elsewhere. Feel free to contribute information; I'll edit this post to add it.
    1. Terminology
    2. Discussion
    3. Front Drive Assembly
    4. Driveline
      1. Transmission
      2. Transfer Case
      3. Driveshaft
    5. Mounting
      1. Engine mount arms and mounts
      2. Transmission and transfer case mounting
    1. Terminology
    Transfer Case: The additional driveline component that AWD cars have which sends drive power forward as well as rearward and controls the power split front to rear. The transfer case is bolted to the output end of the transmission, but is sealed from the transmission and has an independent lubrication oil supply.
    Drop: The portion of the transfer case that is offset from the main driveline and provides drive power to the front differential.
    Semi-Divorced: Describes transfer case mounting BMW used in the E30 325iX and E34 525iX with manual transmissions. The space between the transmission output shaft seal and transfer case input shaft seal is accessible with the two units bolted together. BMW installs a guibo in this space to cushion driveline shock and to reduce the required precision for assembly of the transfer case to the transmission.
    Integrated: Describes transfer case mounting BMW used in the E30 325iX and E34 525iX with automatic transmissions, as well as the E53 X5 and E46 325xi and 330xi with manual or automatic transmissions. The flange on the rear case of the transmission fully encloses the shaft coupling between the transmission and transfer case. The volume between the transmission output seal and transfer case input seal is only accessible by removing the transfer case from the transmission.
    Bearing Block: The casting that bolts to the right side of the AWD oil pan and carries a bearing that supports the extended shaft of the right side inner CV joint. It also carries the right side axle seal. It seals to the oil pan with the same P/N o-ring that the differential uses to seal to the oil pan. This part is specific to the front sump assembly. E30 and E34 bearing blocks are not interchangeable.
    Oil Sump: The combination of oil pan, oil pump and oil pump pickup tube all from the same original application which assemble without modification
    Front Drive Assembly (FDA): The combination of oil pan, differential, bearing block and inner CV joints all from the same original application which assemble without modification.
    2. Discussion
    The 24V AWD swap is electrically nearly identical, but mechanically more complex than the 24V RWD swap. The only electrical difference is the location of the oil level switch and sensor on the engine. The RWD engines have this sensor at the front, while the AWD engines have it at the rear. This is because the RWD oil pans are front sump while the AWD oil pans are rear sump.
    The AWD strut towers are located further forward than the RWD strut towers, giving the AWD cars less caster. The AWD floor pan stamping is different than the RWD floor pan stamping.
    The alignment of the transfer case front output and front differential pinion centerline is an important interface that must be understood when assembling a driveline.
    The bellhousing patterns of the M20 and M50 (and all other 24V engines) are the same, but the 24V engine is leaned over an additional 10 degrees compared to the M20 in order to keep the larger cylinder head under the low BMW "Flying Wedge" hood lines. In a RWD swap, it is possible to bolt the Getrag 260 transmission to the 24V engine. As a result, the transmission is tilted 10 degrees and adaptation of the rear trans mounts and shift linkage is necessary. Once accomplished, this adaptation works well. This is not possible in the AWD E30 because the extra tilt would raise the transfer case drop such that it would interfere with the floor pan.
    Mechanical differences vs. RWD swap:
    -Engine mount arms: The AWD e30 has engine mounts in different locations than the RWD cars. The E36 mount arms will not work. E34 24V engine mount arms appear to be close
    -Brake boost: The AWD strut towers are further forward (less caster) than the RWD strut towers. This has the potential to affect packaging of a hydroboost, but I don't know the specifics yet.
    -Front Drive Assembly (FDA): This is the most obvious complication. If the swap adheres to BMW's original design, then the front diff will bolt to the engine oil pan and the right side axle intermediate shaft will go through the pan. The oil pump, pickup tube and oil pan (collectively: "oil sump") must have interfaces for the front diff and axles, as well as clearance for the AWD front crossmember, which is located forward of the RWD front crossmember position.
    -The entire FDA must come from the same application. The length of the left inner CV joint spline is specific to the differential. The length of the right inner CV joint shaft and spline is specific to the combination of differential, oil pan and bearing block. Bearing blocks do not share bolt patterns and are not interchangeable. Differentials do not interchange outside their original bodies.
    All BMW front differentials are variants of the 168mm rear differentials. There are a wide variety of ratios available. Known examples include:
    2.35 E46 330xd M57 manual transmission
    2.47 E46 330xd M57N manual transmission
    2.93 E46 330xd automatic transmission
    3.07 E53 X5 3.0d manual transmission, E46 330xi manual transmission
    3.23 E46 325xi manual transmission
    3.38 E34 525iX (Does not interchange with other gearsets)
    3.46 E46 325xi and 330xi automatic transmission
    3.64 E53 X5 4.4i
    3.64 E30 325iX European market (Only interchanges with other E30 front gearsets)
    3.91 E53 X5 4.6is
    3.91 E30 325iX US market manual transmission (Only interchanges with other E30 front gearsets)
    4.10 E53 X5 3.0i automatic transmission
    4.10 E30 325iX US market automatic transmission (Only interchanges with other E30 front gearsets)
    I have not verified that ratios in the same "range" can be interchanged between E46 and E53 carriers/cases.
    I do not know at what ratio the carrier break occurs (If any)
    There is a "case breaK". Low ratio cases are cast with more pinion clearance than high ratio cases.
    Differentials for a particular body are interchangeable. For the E30 and E46, different ratios are all used with the same engine, so interchangeability is obvious. E53 6 and 8 cylinder differentials use the same bolt pattern to the oil pan and are interchangeable.
    The E53 front differential will accept the same part number Quaife limited slip differential as the rear of a Z3 1.9. The E34, E46 and E53 carriers all have different widths across the carrier bearings, with the E34 being the narrowest and the E53 being the widest.
    While it is possible to fabricate brackets and use a differential housing with integral intermediate tube bolted to the oil pan rails of a RWD pan, the front sump of the RWD pan would interfere with the AWD crossmember location and steering rack. I do not know if a custom crossmember would have sufficient clearance, or if the rack itself would have to be relocated. A dry sump system would completely overcome this difficulty. If you're capable enough to do this, you really don't need me to tell you how.
    AMC Eagle front differential and mounting
    3. Front Drive Assembly (FDA)
    No production 24V FDA will fit in the E30 AWD engine bay with the stock crossmember and rack location.
    The FDA consists of the oil pan, oil pump, oil pickup tube, front differential, bearing block and inner CV joints from the same application.
    For the passenger side the distance from the side gear splines to the axle seal must be the same for the differential and the inner CV joint cup.
    For the driver's side, the distance from the side gear spline through the differential case, through the oil pan, through the right side bearing block to the axle seal must be the same for the sump assembly as it is on the CV joint cup.
    Need axle assembly collapsed lengths
    Need data to compare track widths of different AWD cars against widths of the bearing block + oil pan + differential assembly from different source vehicles to compare lengths of axle shafts
    The E46 FDA can not be used as it places the axle centerline too far forward to fit in the E30 engine bay. The differential and front face of the sump would interfere with the crossmember, while the rear of the engine would interfere with the firewall.
    3.a. E34 525iX
    [production dates, part numbers, BMW list price(?), pics]
    The International Market E34 525iX is the BMW application that is closest to the E30 in technology and production dates.
    The fore/aft position of the axle appears compatible with the E30 body, as does the fore/aft length of the sump.
    The only available ratio is 3.38. This gearset does not interchange with other front end ratios due to the installation depth of the pinion bearings.
    Originally posted by Nisse Järnet
    The E34 FDA locates the differential pinion in the same position relative to the crankshaft as the E30 FDA does. This allows E30 and E34 transfer cases to be substituted for each other while retaining the non-jointed drive shaft.
    3.b. E53 X5 6 cylinder
    [production dates, models, part numbers, BMW list price (?), pics]
    The E53 body appears to place the fore/aft position of the axle centerline relative to the bellhousing face very close to where it is in the E30.
    The pinion centerline is placed further away from the crankshaft centerline than in the E30 and E34 applications.
    Either 6 or 8 cylinder E53 pans require removal of the "cushion" from the rear face of the E30 AWD crossmember, because the E53 sumps are longer than the E30 sump, measured forward from the bellhousing surface. A lower profile cushion bracket may be built if desired.
    The E53 FDA locates the differential pinion further from the crankshaft centerline than the E30 or E34 FDA's do. This requires the use of a u-jointed driveshaft if using E30 or E34 transfer case.
    The E53 used the NV125 (American built) transfer case, which is much bulkier than the ZF A95 (E30) or ZF A110 (E34) transfer cases. The E53 uses a non-jointed driveshaft.
    Locate info regarding width across the carrier bearings for E46, E34 and 2002 diffs
    3.c. Frankenpan
    Frankenpan
    The E30 AWD pan can be cut apart and surgically interposed into an M50 oil pan. If you think you can do this, you don't need some guy on the internet to explain it.
    Example Frankenpan swap: http://www.e30tech.com/forum/showthread.php?t=78938
    Additional Frankenpan swap: http://www.e30tech.com/forum/showthread.php?t=21774
    Third Frankenpan swap: http://www.e30tech.com/forum/showthread.php?t=100870 (This one uses M20 iX mount arms and mounts the engine at the M20 angle)
    4. Driveline
    4.a. Transmission
    Option 1:
    ZF 5 speed manual.
    The S5D-310/320Z transmission was used in the E34 525iX with a rear case half specific to that application.
    The AWD rear case half PN is: 23111224968
    Photos of the E34 rear case half: http://www.e30tech.com/forum/showpos...&postcount=164
    This rear case half does NOT have the same bolt pattern for mounting the transfer case as the E30 AWD Getrag 260 rear case.
    While it can, in theory, mount the E30 transfer case, it would still require an adapter between the two. The guibo bolts could be spaced by the adapter thickness, similarly to the way the front differential guibo is spaced to provide extra spline engagement with the OE driveline.
    Originally posted by chris325ix
    The S5D-310/320Z was also used in early (up to 10/2003) E53 X5 3.0i vehicles. It uses a different rear case half. That part number is: 23117511936
    This case mates the NV125 transfer case with integrated mounting.
    This rear case half may be the easiest to adapt to an alternative transfer case, as many more transfer cases use integrated mounting than use semi-divorced mounting.
    For example, the E30 transfer case for automatic transmissions uses integrated mounting and *may* be adaptible to this rear case half.
    Option 2:
    Getrag 5 speed manual.
    As mentioned above, the Getrag 260 used with the M20 will also bolt to 24V engines. If used with the original transfer case mounting, this will cause the transfer case to interfere with the floor pan.
    However, an adapter could be made that would rotate the transfer case back to its original position. This would involve spacing the guibo as mentioned above with regard to use of the E34 ZF rear case half.
    The AWD rear case for the Getrag 260 was also used on the Z1 roadster to mount the front end of the torque tube.
    Option 3:
    4HP22 automatic.
    The automatic AWD E30 cars have integrated transfer cases.
    In addition to having the rear case half specific to the AWD application, the 4HP22 transmission has a separable bellhousing. This means that the bellhousing can be modified to mate the 4HP22 to the 24V engine.
    Example: http://www.e30tech.com/forum/showthread.php?t=117333
    Are there any applications in which BMW mated the 4HP22 to the 24V engine?
    Can an A4S-270/310R bellhousing bolt to a 4HP22 (or anything else)?
    I am currently working on an automatic AWD 24V swap in which the transmission mounting pattern in the bellhousing will be removed via wire EDM, rotated 10 degrees and welded back into place.
    4.b. Transfer Case
    Option 1:
    E30 Transfer Case.
    ZF A95
    Manual transmission variant
    Automatic transmission variant
    Option 2:
    E34 Transfer Case.
    ZF A110
    Option 3:
    Borg Warner 4472.
    4.c. Driveshaft
    The stock E30 front drive shaft is a one-piece unit using a guibo at the front end. It is not jointed and goes straight from the T-case front output splines to the diff input flange. The E34 and E53 front driveshafts are similar.
    The E46 front driveshaft has two u-joints. These are required because the transfer case front output is not aligned with the differential input flange.
    No BMW driveshaft u-joints are rebuildable.
    A front driveshaft must include some plunge. The engine block, aluminum transmission case and aluminum transfer case will expand as they start from cold and come up to operating temperature. The driveshaft will not have the same change in length due to temperature change. To prevent excess loads on the cases, shaft and bearings, the front driveshaft should be able to accomodate the change in length. The stock E30 and E53 driveshafts do this via the guibo and by the fact that they are not rigidly retained in the T-case.
    The BMW 4 bolt differential flange is common to rear and front differentials. The 4 bolt flange at the rear of the stock E30 iX rear driveshaft will mate to the input flange on an E46 front differential.
    This means that an adapter yoke produced by Jags That Run can be used to build a front or rear driveshaft using domestic 1310 series universal joints, which are readily available.
    This yoke could be used at the differential end of either front or rear driveshaft to serve as the basis for a custom shaft.
    Why You Might Need One. When doing a V8 swap into a BMW, the BMW U-joint is non-serviceable and requires special machining to replace. Stealth Conversion’s heavy-duty BMW driveshaft conversion flange has the same bolt pattern and pilot dimensions as the stock BMW driveshaft flange, but it uses the road-tested Dana 1310
    5. Mounting
    5.a. Engine mount arms and mounts
    E34 24V mount arms are close to the right location.
    The iX uses a cast aluminum cross member with stamped steel "towers" to carry the engine mounts. Modifying these towers or building new ones from scratch is easier than building mount arms from scratch.
    From: http://www.r3vlimited.com/board/show...7&postcount=18
    Originally posted by nando
    5.b. Transmission and transfer case mounting
    E53 NV125 T-case
    5.c. Axles
    While the inner CV joints must match the FDA, the outer CV joints must match the hubs and wheel bearings.
    • Jun 2010
    • 2796
    Info to add in later: http://www.r3vlimited.com/board/show...&postcount=525
    • sassen
      • Nov 2013
      • 28
      Engine Mounts
      Originally posted by The Dark Side of Will
      Awesome compilation.
      1. As far as the mounts, it would seem to me that one may Drill a third hole inwards and that would provide use of existing engine absorbers/mounts and provide the safety catch that is needed to seat that mount snug??? Leaving the outermost hole unused...
      2. E46 and X5 would use the same mounting holes on the engine block, as M50, therefore one of those engine mount arms esp X5 may just be longer and reach our targeted motor/absorber mount.
      3. Just use the stock E30 ix engine mount arms, they seem to work perfectly for other people it seems, at least 3 of your links to the builds did so.
        • Jun 2010
        • 2796
        Thanks.
        That's one of the things I'm going to look into when I get my S62 on the stand... Can the E30 mount towers be modified to located the mounts differently? Worst case scenario would involve using stock mount arms that put the mounts close to where they need to be, then building towers from scratch to hold the mounts.
        I haven't done as much looking at the 24V hardware as I have at the 32V hardware, but this is also a good point. BMW made a lot of different mount arms and some may be closer than others.
        Those put the 24V engine at the same angle as the M20... which means a lot of fab is necessary to get the axle/diff level. The M20 mount arms work for "frankenpan" swaps because those swaps use the portion of the M20 pan that mounts the diff. Obviously that pan is designed to work at the M20 block angle.
        However, most of the people who want to do 24V swaps want to bolt up one of the production 24V AWD sumps and call it a day.
          • 34830
          should update this thread with the pictures I posted including the steering rack and engine mounts. the E34 mounts arms are definitely not as primo looking as they appear the first time I mocked it up.
          IMO, if I were starting from scratch again, I'd skip the E34 stuff and go straight for the X5 parts with a u-jointed front shaft.
          I agree that using the E30 mount arms and pan is a poor solution. It causes so many other issues with things like the brake booster. Also, as has been repeated many times, the E30 ix front diff is really weak, if you use the E30 pan you are stuck with possibly the weakest diff made by BMW.
            • Jun 2010
            • 2796
            link?
            The jointed driveshaft shouldn't be hard to build... The E46 front diff input flange has the same 4 bolt pattern as the older BMW rear diffs. the E46 input flange *should* install to the E53 diff (although you'll have to be careful to get the backlash set correctly on the pinion bearings). With that in place, you can use the Jags That Run yoke pictured above to go with a US domestic 1310 u-joint and standard weld-in yoke. That's 3/4 of the front driveshaft. The T-case end can be built using the upgrade stubshaft available from another user on this forum.
              • 34830
              I think they're all in here:
              in the original pictures the engine is at least 1" too far back relative to the subframe. when you posted the measurements from the bellhousing face (which should be copied here too), I realized that I had to move it forward. this is when I also found all the interferences with the steering rack..
              • chuckdizzle
                • May 2011
                • 211
                Are there any rough budget estimates for this conversion? Just the conversion parts, not the cost of the donor motor.
                  • Jun 2010
                  • 2796
                  There's this post: http://www.r3vlimited.com/board/show...0&postcount=56
                  Which includes the steering rack and one mount arm, but I never saw engine mounts.
                  Lol... we barely know what those parts are at this stage... let someone finish a non-frankenpan swap first and then we might be able to tell you.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    This is probably the wrong place, but I-Love-AMC Eagles. For the under informed, Google AMC Eagle SX/4. I will own another one. So kickass.
                    On another note, great set of information here. Good job!
                    Originally posted by Andy.B
                    I was born on 3/25…
                      • 34830
                      Too many variables, since there's no "one" way to do this swap. Some parts are difficult to find and very expensive new. Also, since we're still trying to figure it out, a lot of money gets spent on parts that don't end up being used because they didn't fit quite right or there was a better option.
                      cheapest is definitely the frankenpan route using all E30 ix parts. the drawbacks are too significant for me to ignore, though.
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        MattM, up here in the great white north, did an m52 swap into his ix but never got the motor to run properly. I believe he scrapped the entire car.
                        Originally posted by codyep3
                        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                        2001 silver/Blk 325 cabby. SOLD
                        2002 325xit Sil/blk. SOLD
                        2010 F650gs twin
                          • 34830
                          he did the franken pan which forces a remote booster or hydroboost setup
                          bummer that he scrapped it..
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            Wooops i got a 3rd set of E34 gearbox and TC haha, good to have spares :)
                            Didnt see any picture in the thread so heres one:
                            E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                            E30 M50 6 spd 764whp @ 24psi.
                            E30 M20 6 spd 675whp.
                            • flyboyx
                              • 8371
                              i've been looking on ebay at e53 parts. i have come to the conclusion that i don't think they are going to work very well.
                              here are my reasons:
                              1) the axle hole in the 6 cyl oil pan is pretty close to the middle of the pan. the e34's is pretty close to the middle too but this one looks like it might be about the same or a tad further forward. i don't see any gains here as far as helping the clearance issues. do you happen to have one to measure Will?
                              2) i see trouble with the axles too. it appears that on the outer portion, the splines are larger than will fit inside the e30 ix hub. the design looks really similiar to e46 axles. i can tell you for a fact an e46 axle will not even come close to fitting an e30 hub. i know this because i purchased one to try it.
                              also, the abs is a completely different system and not compatible with the e30 style. you would need to find a way(if possible) to machine a shoulder on the e53 axle to make an e30 abs ring fit.
                              perhaps you can have the end of the shaft re machined so the outer portion of an e30 ix axle will fit on the end.
                              3) as we have already surmised, the diff will not be in alignment with the output of the transfer case. this will require a custom u-jointed drive shaft.
                              personally, i suppose these parts could work. it appears to me that it would be more difficult to make work than sourcing an e34 ix sub assembly. it seems that bmw's x5 technology has advanced a long way since the mid 80's.
                              these are just my thoughts. i hope you don't mind my contribution Will.
                              Gigitty Gigitty!!!!
