24V AWD Swap Knowledge Base
This is a sticky topic.
  • The Dark Side of Will
    • Jun 2010
    • 2796
    #1096
    Not the left to to right tilt... the front front to back tilt. This will be an angle of 5 degrees or less.
    So yes, car would need to be on a level & flat surface. The top of the intake plenum would actually be a good reference for an angle finder.
    I thought the M20 was 20 degrees leaned over and the 24V engines were 30 degrees.
    • Eskie
      • Dec 2014
      • 162
      #1097
      Alright, i'll measure one of mine in a bit
        • 34839
        #1098
        AFAIK it's not tilted at all. The bottom of the oil pan is essentially flush with the subframe.
        • Eskie
          • Dec 2014
          • 162
          #1099
          Yeah I was just out measuring it with my phone level app. It’s dead nuts at 0 degrees on the top of the manifold and valve cover.
            • Jun 2010
            • 2796
            #1100
            Weird... because the driveshaft definitely comes out of the transmission higher than it goes into the diff... but I wouldn't have designed a system using a giubo with a static angle.
            • Eskie
              • Dec 2014
              • 162
              #1101
              I mean I also measured it with my iPhone app that’s only accurate within 1 degree
                • Jun 2010
                • 2796
                #1102
                I don't doubt that... I guess BMW could have made the manifold level with the engine tilted. It would definitely be out of the ordinary for it to be level.
                • nomansland92
                  • 1657
                  #1103
                  I looked into this awhile ago and zeroed my angle meter off the pinch weld like were the airbox sits and I believe the motor was 2-3 degree tilted back, I cant remember exactly.
                  Sent from my SM-G892A using Tapatalk
                  IX being restored here
                  Ix turbo build here
                  • Eskie
                    • Dec 2014
                    • 162
                    #1104
                    We've got an N63 out of an E71 on the engine table getting warranty valve seals done. I don't know if any pictures of the front diff would be relevant to this thread but I took some:
                    He's going to be on it for a while, so I can grab more pictures if needed.
                      • Jun 2010
                      • 2796
                      #1105
                      Snazzy, but I'm not sure if anything is relevant to the E30 iX.
                      The left mount behind the left axle is something BMW has always done in their SUV's, apparently.
                      Also, the T-case is extremely compact.
                      • Eskie
                        • Dec 2014
                        • 162
                        #1106
                        We also have a ATC350 t-case from a F02 we are throwing out. Its all disassembled if there is any interest in pictures there..
                          • Jun 2010
                          • 2796
                          #1107
                          WOuld be interesting and there are some guys here who have used the ATC... but you may not have it anymore at this point
                          I think it's pretty awesome that the ATC 700 bolts in place of the ATC 350.
                            • Jun 2010
                            • 2796
                            #1108
                            I'll need to pull the airbox and AFM to get a better look, but it looks like the RWD mount arms will interfere with the AWD steering shaft, but probably not the rack itself.
                            I already knew that the spool valve on the iX rack would interfere with the E53 front diff and had figured out a candidate method for rotating the rack. Rotating the rack will require an "exotic" 3 or 4 joint steering shaft geometry, but that's nothing new in the hot rodding world. It'll just have to reach over the RWD mount arm. I was hoping that only E53 based swaps would need to rotate the rack, but maybe they all will. Feh.
                            • Eskie
                              • Dec 2014
                              • 162
                              #1109
                              I still have it, it’s in a box under my desk
                                • Jun 2010
                                • 2796
                                #1110
                                I have been thinking that I might need to take an ATC-350/700 input shaft and cut off the female splines that mate to the output shaft of an GS6-53BZ so that I can use those splines as the basis for a shaft coupler to install whatever T-case I want.
