Tire size question - 205 /65 R15
  • 95BMWIC
    • Apr 2012
    • 353
    1990 325ix has the 15" Moda by BBS Rims - currently has 205/55 R15 tires..
    I found a great deal on Snow tires - however they are 205 /65 R15..
    I ran the calc and the size is 6.76% diameter variance (Anything more than 3% is not recommended)- i.e its a little taller sidewall height..
    But realistically a little taller tire should not be a problem - I have no lowering on this car.. Anyone have a thought on this? Nando?
    It would only be run in the winter..
    • 34839
    What offset?
    Thats less than 1" diameter difference, i think it should work but there could be rubbing at full lock.
    I'd prefer 195/60 than something so oversized, but a deal is a deal..
    • Northern
      I like cupcakes & sh!tboxes
      • 5246
      I ran 195/70/14 on basketweaves in the winter, and it didn't cause any issues. Looks pretty great considering I was going from bald puny 185/60/14's left from the PO. Only had issues with them when I ran them on my iS because it was semi-low
      Originally posted by priapism
      Originally posted by shameson
      • chuckdizzle
        • May 2011
        • 211
        it shouldn't be an issue, especially at stock IX ride height.
        • 95BMWIC
          • Apr 2012
          • 353
          Sorry to bring this thread back..
          What about 185/55 R15?
          Using this Calculator it should be ok..
          Bridgestone has a rebate on ECOPIAs..
          • spdracrm3
            • Sep 2009
            • 959
            they'll work just 3.6% smaller and much narrower which is always better for snow tires (might need narrower rims? could be pushing it a bit on stock rim width for mounting) . speedo will probaby be right on with these on too
            Angus
            88 E30M3 X2
            89 325IX
            92 R100GS/PD
            • 95BMWIC
              • Apr 2012
              • 353
              Last One.
              I have an option for the Yokohama EnVigors also with a rebate.
              The size is 195/60 R15 - My ET is 35
              I wonder if this will fit? - (A litte bigger) 1.4% - I think it is a better tire..
              • spdracrm3
                • Sep 2009
                • 959
                Originally posted by 95BMWIC
                Last One.
                thats what size im running on my snows
                Angus
                88 E30M3 X2
                89 325IX
                92 R100GS/PD
                • 95BMWIC
                  • Apr 2012
                  • 353
                  Thank you sir!
                  I just placed my order for the Yokohama Avid ENVigor tires from Discount Tire direct - in 190/65 size..
                  I have the same tires on my wife's E46 and they are quiet and are wearing well.. so I figured they should work on the IX..
                  Now I need to locate some steelies that will work for my winter tires as winter is approaching!!
