3.64 front
  • downforce22
    • Aug 2009
    • 3192
    3.64 front
    So I may have just picked this up....
    I figure there can only be so many and they will stop popping up on ebay.de.
    http://www.ebay.com/itm/251383115521...84.m1438.l2649
  • spdracrm3
    • Sep 2009
    • 959
    lucky ,just drove the IX in the snow yesterday first time in awhile and it reminded me how much it needs 3.64 gearing (first gear is useless)
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • The Dark Side of Will
      • Jun 2010
      • 2796
      I'd like a 3.64 also... I have a 3.64 VC rear set up with the E36 rear cover. I had to modify the VC LSD VSS trigger wheel to fit because the E36 wheel doesn't fit the VC diff.
        • 34844
        there are probably thousands of them, all early ix's had them.
        now you need a matching 3.64 with a working VC.. I'll bet that's even harder to find!
        • Northern
          I like cupcakes & sh!tboxes
          • 5262
          I wish my PO kept the rear 3.64, he must have binned it or something, the car did come with the front 3.64 at least.
          Originally posted by priapism
          Originally posted by shameson
          • downforce22
            • Aug 2009
            • 3192
            I got it as a spare for my euro. Who knows, may want to try to reinforce it someday like mw044's turbo ix...
            • Stuffy
              • Jul 2011
              • 56
              A cooling system for the front diff would be wicked cool. And does the rear need to have a vc? I've heard you could use a LS...
                • 34844
                heat isn't really an issue, the components are just too small.
                but really, unless you're drag racing and pushing 500hp you don't need to think about it that hard.
                • Northern
                  • 5262
                  I'm really interested in the 3.38 e34 internals myself, would be nice.
                    • 34844
                    pretty sure they don't fit in the E30 housing, also the E30 CV shafts won't work because E34 are larger diameter.
                    • flyboyx
                      • 8371
                      guaranteed they won't fit. unfortunately, all those parts are related. you will need perhaps 7 or 8 items plus a 3.38 rear diff to make that stuff work
                      axles, oil pan, etc.....
                      Gigitty Gigitty!!!!
                        • Jun 2010
                        • 2796
                        You'd need to do a 24V swap PLUS install a 3.38 rear to make use of the E34 front diff.
                        • nrubenstein
                          • 3148
                          There is a Z3 Torsen 3.64 option.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • Northern
                            • 5262
                            Just saying the 3.38 can be had from some e36 M3s. I thought that was common knowledge.
                            I was under the impression after reading chris' thread that the 3.38 did fit, and it was just the 3.23 that didn't, but this just means less messing around with what I have.
                            So I just bought a 3.64 R&P from Wangan to match the rear diff to the front 3.64 I have, so I'll be joining you in 3.64 land soon.
                              • 34844
                              No, it only fits the e34 pan. Nothing is compatible with the e30 ix front diff.
