Subframe Question.
  • z122643
    • Aug 2011
    • 286
    Subframe Question.
    I can't find the original post on this so sorry for the repeat.
    I am finally ready to replace my (very rusted) rear subframe.
    The question is what is the difference between the normal E30 rear subframe and the iX?
    Can I get away with using a normal E30 subframe?
    **If anyone has a no rust rear subframe for sale, I'm interested.
    [/SIGPIC]"we are so totally screwed!"
  • spdracrm3
    • Sep 2009
    • 959
    different bushings
    the IX subframe bushings are different so you would have to change them in the new subframe if its and i/e, other wise its all the same.
    the reason the subframe part # is different on sites like RealOem is the the subframe comes with bushings installed so had to have a different #
    i just converted an i subframe to an IX for my car to fix a toe issue ,just pressed in new IX subframe bushings
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • z122643
      • Aug 2011
      • 286
      Is that really all? Wow... ok then that make my life much easier.
      • Northern
        I like cupcakes & sh!tboxes
        • 5262
        Yeah that's all. Just use ix bushings with the ix Subframe washers/Subframe bolts and everything will line up like normal.
        Originally posted by priapism
        Originally posted by shameson
        • spdracrm3
          • Sep 2009
          • 959
          yes thats all , the subframe bushings are taller to correct suspension geometry due to the IX sitting higher ...(lowers subframe in relation to body) , and yes be sure to use IX washers if staying stock height, if lowering car you can use standard i bushings/subframe to keep geometry correct due to sitting lower (close to same height as stock i)
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
          • BmwRacer
            • 5
            I need a new subframe and trailing arms for my 'iX' because
            I smashed a curb sideways and bent an arm and the arm mounts on my subframe. Is this confirmed accurate? Can i just buy an 'i' subframe and use the 'iX' bushings?
            • The Dark Side of Will
              • Jun 2010
              • 2796
              Yes
                • 34844
                you will need to swap the rear hubs/e-brakes on those RWD trailing arms. may as well do new bearings and brake shoes.
                  • Jun 2010
                  • 2796
                  Oh yeah, the iX hubs have different offset than the RWD rear hubs.
