Spring rates etc
  • Nisse Järnet
    • Aug 2013
    • 1221
    Spring rates etc
    Im about to order the GC coil kit with Koni race and probably camber plates but what spring rates do you guys recomend?
    The car will be driven on the street for the most part but is not a daily so i dont care much about comfort, handling is nr 1 prio.
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
  • Mr. Tasty
    • Jul 2011
    • 3421
    Originally posted by nisse järnet
    im about to order the gc coil kit with koni race and probably camber plates but what spring rates do you guys recomend?
    550f/750r
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • IronFreak
      • Dec 2012
      • 3702
      Originally posted by codyep3
      550f/750r
      Instagram @rebellionforge
      • Nisse Järnet
        • Aug 2013
        • 1221
        Ok thanks guys! I dont want the front inner tire to lift during hard cornering :)
        • IronFreak
          • Dec 2012
          • 3702
          Thats what I have, and will have on my Z coupe as well. I would call and double check with Mark at GC or PM him on here "GCMARK". He might have some insight on your setup, being that its an IX that we as coupe owners are missing.
          • Nisse Järnet
            • Aug 2013
            • 1221
            Yeah im talking to him too :)
            Is a stiffer front bar the best way to reduce front wheel lift? Or does a stiffer one at the rear help out?
            • IronFreak
              • Dec 2012
              • 3702
              Can't answer that. I'm sure the dynamics with the IX suspension is a little different. I know several people around here that don't run a rear bar at all. I think you would control that lift more with a spring then the bar, although it will help. The bar is trying to keep the car level, so if it's doing it job, but the opposite corner spring compresses on a hard turn, the bar will probably create lift......I could be totally wrong but that's how I would see it.
              • Nisse Järnet
                • Aug 2013
                • 1221
                Yeah thats true! So probably springs a bit on the hard side is a good starting point?
                Just wonder how thats going to perform on the street thats not as smooth as a track :P
                The car would see like 90% street use.
                  • 34839
                  I would do 400/600.
                  Many people responding to this dont have an ix. 550/750 will be really stiff - i had 600/700, it was nice on a track but a bit much to dd. I'd also pair them with konis, if you're shortening the housings (you should), get the race inserts. The ride shoud be pretty decent with lots of travel and good damping.
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    Im not going to daily the car so that's not very important, however it will mostly be used on the street so a too stiff setup may be no good on the bumpy roads? Like loosing traction in corners because its too stiff causing the tire to "bounce off" some small bumps if you know what i mean. Usually the roads are pretty good so it might not be a real problem.
                    And i also have a little fear of lifting a front inner tire but maybe not on the street :)
                    Yes i will go with Koni race and shorten the housings.
                      • 34839
                      yes.
                      I wouldn't worry about front innner tires lifting. if that happens it just means you're driving the car properly...
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        The finish ix turbo guy had some problems with the handling when the inner tire lifted. The car started to drift like a rwd and when trying to counter steer it violently changed direction due to the power coming back to the front tires :P
                        I want to avoid that as much as possible!
                        • The Dark Side of Will
                          • Jun 2010
                          • 2796
                          A stiff bar will *INCREASE* the tendency to lift the inside tire
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            Yeah i thought a bit more and agree, but what about a stiffer in the rear?
                              • Jun 2010
                              • 2796
                              Bars change the car's diagonal dynamic weight distribution.
                              A stiff rear bar will lighten the inside rear while putting weight on the inside front.
                              Bars hurt traction at the end of the car they are installed on by increasing the weight split from inner to outer. This reduces the total grip at that end of the car. However, if the car reduces body roll such that a poor suspension design can make better use of the tires, then grip may go up. There are multiple effects at work.
                              Each bar has an effect on all four wheels, and these effects are additive with the effects of the springs.
