Spring rates etc
  • Nisse Järnet
    • Aug 2013
    • 1221
    Needs some prep and paint, then new bearings and hubs :)
    I went with 440/650 springs.
    Do you guys use the provided koni race bump stop?
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
      • 34839
      yeah, I did. did you shorten the housings 2"?
      • Nisse Järnet
        • Aug 2013
        • 1221
        I think i ended up with 1.9" The koni gland nut goes just below the tube and the threaded spring sleeve sticks up like 3-4mm over the tube so I'm a little bit on the high side maybe but I think the adjuster will be around the middle. Hopefully:)
        • Nisse Järnet
          • Aug 2013
          • 1221
          Oh by the way, where do you other ix coil users have the spring adjuster positioned? And what ride height do you get from it? :)
          • Nisse Järnet
            • Aug 2013
            • 1221
            What Koni shock should i run in the rear? Any tips? :)
            • nrubenstein
              • 3148
              For the rear, I'd run the standard GC shortened Koni.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
                • 34839
                Shortened?
                • mw044
                  • Dec 2008
                  • 59
                  Originally posted by nando
                  yes.
                  I wouldn't worry about front innner tires lifting. if that happens it just means you're driving the car properly...
                  I'm the one that Nisse Järnet mentioned, that had problems with lifting front wheel. That is actually not OK with 4wd that has enough power to spin the wheels. With stock ix, no problems.. :D
                  When your spring rates are setup in a way that car wants to lift the front wheel, then the front power escapes from that wheel and car basicly becomes rwd. That causes huge oversteer. When you countersteer that, car shoots towards the tangent when front wheel again hits the ground.
                  Look closely to this picture (which wheel is off the ground?):
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    Whats the best way to solve this, stiffer front springs and no front swaybar?
                      • 34839
                      that picture was with H&R sports and race slicks, and basically the peak of my driving career.. lol. coilover springs will easily solve it, the rear springs in that case were too soft as were the overall rates. too much weight shift to the rear, too much body roll. I haven't had that issue in years (I think I switched to coilovers in 2008?).
                      also, my ix isn't stock. But I do suppose it has slightly less power than his turbo. :p
                      what you have posted above should work great. you could also make swaybars to upgrade the roll stiffness if you wanted.
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        OK sounds promising! :) I'll try with the parts I have first, hopefully it works great! And I'm mostly driving on the street on normal tires.
                        • TehRaydarlover
                          • Mar 2013
                          • 544
                          bump :)
                          Ordering my coilovers from GC
                          They suggested getting their custom valved koni struts and 440F 680R springs. I'm having them shorten them by 2" and using their camber plates & RSM.
                          Anyone familiar with their custom valving vs the standard sport or race insert? GC said they are valved to be in between sport and race as far as aggressiveness but have be more adjustable than the sport. The spring rates sound about right from reading above and talking with GC.
                          Any other advice before I send them in?
                          Thanks!
                          Ray
                          Build Thread
                          Rear Diff Rebuild
                          Rebuildable Viscous Coupling
                          Transfer Case Rebuild
                          "Life is simpler with 12 valves"
                            • 34839
                            Sounds good to me. The race inserts are pretty stiff, although it rides like a Cadillac compared to the custom valved Bilsteins.
                            • TehRaydarlover
                              • Mar 2013
                              • 544
                              Cool, I was surprised it was only $300 more to send them in and have them shorten, reinforce the housings, powdercoat and assemble everything vs. Sending me the parts to do it. The first guy I talked to "Devon" said that they actually remove the strut tube and weld in a new one
                              Build Thread
                              Rear Diff Rebuild
                              • Nisse Järnet
                                • Aug 2013
                                • 1221
                                I dont think the race inserts is too stiff? I started with them on the softest setting but had to stiffen them up a few "clicks" to stop the car from being to bouncey :)
