Oil Light and Transmission question
  • Imprezme
    • Aug 2012
    • 35
    Hey guys so i recently picked up a 91 325ix, the other day i was driving the car and the oil light started blinking on the dash. First time it ever happened, when i came to a stop light the light would flicker. When i stepped on the throttle it would go away. Any ideas what might cause this? oil pump failing? or maybe the oil that im running in the car? Light only seems to come on when the engine is fully warmed up.
    Another question i have is when the car is in neutral i can hear a noise, but when im clutched in the sound goes away. i assume that's my input shaft?
    Any ideas or information toward the right direction would be helpful. thanks!
    Current:
    13 Mitsubishi Evo X
    91 BMW 325IX
    Past:
    86 BMW 325es
    09 Subaru WRX
  • 325ixa
    • Jun 2011
    • 73
    i have a dumb question, have you chekeck oil level, on dipstick?
    second is probably clutch bearing.
    • Nisse Järnet
      • Aug 2013
      • 1221
      The sound from the trans is the input shaft bearing in the gearbox propably, not much to worry about.
      Try to measure your oil pressure.
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • 101
        • Jul 2011
        • 764
        Agree on the transmission shaft input bearing being the likely cause of the noise.
        What weight of oil are you running?
        101
        The E30 collection:
        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
        1987 325is - Delphin / Black Sport (son #3's)
        1987 325i Convertible - Triple Black
        1989 325iX Coupe - Diamondschwarz / Black Comfort
        1990 325iX Coupe - Sterling Silver / Grey Sport
        1981 Fiat 124 Spider 2000 - Green / Tan
        1998 Volvo V70 GLT - White / Tan
        1998 Volvo S70 T5 manual - White / Taupe
        2001 Ford Windstar - Silver / Grey (parts hauler)
        2006 Lexus GX470 - White / Tan (tow rig)
        • The Dark Side of Will
          • Jun 2010
          • 2796
          Yes, what weight? If running multiple viscosity oil and the 2nd number is significantly lower than what BMW specifies, then you could see low oil pressure at hot idle.
          I don't have specs in front of me, but if BMW asks for 10W30 and you're running 5W20, that might happen.
          • Northern
            I like cupcakes & sh!tboxes
            • 5284
            10w40 winter/ 20w50 summer is typically what I run, since it occasionally dips below -10 in the winter and just shy of 40 in the summer.
            Originally posted by priapism
            Originally posted by shameson
            • Imprezme
              • Aug 2012
              • 35
              thanks for the info guys, i believe the pass owner was running 5w30. ill give the oil a change and see what happens before i measure the oil pressure.
              so input shaft bearing, nothing to worry about?
              Current:
              13 Mitsubishi Evo X
              91 BMW 325IX
              Past:
              86 BMW 325es
              09 Subaru WRX
                • 34844
                that chart is nearly irrelevant now - oils have improved a lot since it was made ~30 years ago, especially synthetics.
                • Northern
                  • 5284
                  Still a better guideline than throwing 5w30 in.
                  I also don't think the majority of e30/m20 owners run synthetics.
                    • Jun 2010
                    • 2796
                    A 10W30 is a 10W30 as far as viscosity goes... and the viscosity is what results in the oil pressure warning.
                    HOWEVER, low oil pressure hot *could* be a sign of worn bearings, but changing the oil is the first step.
                    My Pontiac 6000 AWDwith 3.1 pushrod V6 would light the oil pressure light at heat soaked idle also. I swapped in a high volume oil pump but kept the original pressure regulator spring and the problem went away.
                      • 34844
                      it is and it isn't. a 10w30 synthetic and a 10w30 conventional for example are not the same at all. the conventional will have thinners and additives in the base stock to make it flow at lower temperatures. the chain of molecules in the synthetic is different in that it already flows better at low temperatures without additives, but it expands to provide protection at higher temps.
                      I'm willing to bet if you tested any decent oil made today (conventional or not) it would outperform an oil made in 1985 by a pretty good margin. Synthetics are just better, and the conventional oils have a lot better additives packages than they did 30 years ago (which is what makes them work at all to begin with).
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        I always used 5w40 synthetic when my M20 was stock (and still in the car hehe)
                        Never had a problem!
                        I would still try to check the oil pressure just to be sure, a ~25 year old oil pressure switch might not be very accurate either.
                        • nomansland92
                          • 1657
                          As for the transmission noise it's probably the layshsaft bearings, seams to be pretty common with high miles.
                          IX being restored here
                          Ix turbo build here
                          • Imprezme
                            • Aug 2012
                            • 35
                            Gonna give it some new oil tomorrow, see how it works out. Been waiting for a brake light sensor to come in before i start working on the car. Car seems to also take forever to start up, takes like 5 seconds to crack and it will start, guess i gotta check for vacuum leaks
                            Current:
                            13 Mitsubishi Evo X
                            91 BMW 325IX
                            Past:
                            86 BMW 325es
                            09 Subaru WRX
                              • Jun 2010
                              • 2796
                              What I meant was...
                              The viscosity rating is based on a standardized test. The performance of two products with the same score on that standardized test is going to be the same.. on that test.
                              The viscosity test has nothing to do with film strength, ZDDP content, or even with viscosity at other than the two standard test temperatures.
                              So... yes, a 10W30 is a 10W30 is a 10W30 is a 10W30 from the perspective that they all score the same on the standard test. Yes, those products can ALSO have very different performance on other tests or operating conditions other than the test conditions.
