Lifetime front axle boots
  • Nisse Järnet
    • Aug 2013
    • 1221
    #31
    I would have bought if they'd fit E34 axles :P
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • Bimmer_man
      • Jan 2013
      • 1477
      #32
      I don't know the difference between the two. But if it means making another mold then that's a whole new ball game.
      Float like a cadillac sting like a Bimmer!:)
      • nomansland92
        • 1657
        #33
        I'm lucky to get 20k out of my boots, I had to raise the car another 1" to help some.
        IX being restored here
        Ix turbo build here
        • Nisse Järnet
          • Aug 2013
          • 1221
          #34
          The inners might fit, i think it was 2mm bigger diameter on the E34.
          The outers i think not :P its like 8mm bigger..
            • 34844
            #35
            pretty sure inner E34 are identical to the inner E30. outter E34 are the same as the outter E46.
            I'm somewhat interested. I don't think there's anything wrong with the material (it's meant to hold the grease inside it, der). I think most of the damage is from exhaust heat and lowered cars.
            the only outter boot I've had fail in 12 years is from tracking the car and getting the hubs up to like 900 degrees. the boot didn't really even fail but it melted a bit and a little bit of grease came out around the clamps.
            if you are stock and failing boots ever 2-3 years I don't know. Seems wrong. even with extreme lowering I get about the same amount out of mine.
            What would be worth it to me would be to not have to replace them as often. I basically keep them in stock since I know they will only last so long. but mostly it's because they rub together and the exhaust heats them up..
            • Nisse Järnet
              • Aug 2013
              • 1221
              #36
              E30 and E34 (and E46 on the outer) have different part number on the inner but they might fit anyway :) I dont have any E30 boots i could try on the E34 parts..
              But if anyone can measure inner diameter of the E30 boots i can check the E34 ones.
                • 34844
                #37
                I've had them side by side, can't tell any difference
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  #38
                  Ok cool, then I might be interested in inner boots :)
                  • rampart05
                    • Jan 2009
                    • 155
                    #39
                    I'm in
                    1. Madman23
                    2. nomansland92
                    3. Stonea x2
                    4. AWDBOB
                    5. Shadowman
                    6. Fight4life28
                    7. Stuffy
                    8. Rampart03
                    • madman23
                      • Jan 2007
                      • 498
                      #40
                      Any headway on this?
                      • Stuffy
                        • Jul 2011
                        • 56
                        #41
                        ^seconded^ Somehow one of my boots tore on me this week... Fack!
                        • Bimmer_man
                          • Jan 2013
                          • 1477
                          #42
                          It's still something I want to work on just it's an expensive endeavor the material is going to be pretty robust and expensive. So as it sits I'm trying to gather the funds then see if its something that's even feasible to do.
                          • Wille30
                            • Sep 2012
                            • 89
                            #43
                            Just bringing this back up...I'm doing mine the second time in 2 years, I would love to not worry about it
                            1. Madman23
                            2. nomansland92
                            3. Stonea x2
                            4. AWDBOB
                            5. Shadowman
                            6. Fight4life28
                            7. Stuffy
                            8. Rampart03
                            9. Wille30
                            • 2santiago
                              • Aug 2015
                              • 84
                              #44
                              1. Madman23
                              2. nomansland92
                              3. Stonea x2
                              4. AWDBOB
                              5. Shadowman
                              6. Fight4life28
                              7. Stuffy
                              8. Rampart03
                              9. Wille30
                              10. 2santiago
                              I'm in at #10
                              • AWDE30
                                • Jul 2006
                                • 762
                                #45
                                1. Madman23
                                2. nomansland92
                                3. Stonea x2
                                4. AWDBOB
                                5. Shadowman
                                6. Fight4life28
                                7. Stuffy
                                8. Rampart03
                                9. Wille30
                                10. 2santiago
                                11. AWDE30
