Track prep my iX
  • furwolf
    • Sep 2009
    • 71
    Track prep my iX
    Crazy times, I went from potentially selling my iX to track day with it....
    So I signed up for a track day at the end of the month. I wouldn't mind taking my E46 325iT, but it's an automagic. I think it's the iX's time to do what it does best. My goal is to keep up with or beat the 2 Stock FRS's that are going with me.
    About the car
    Koni Adjustables and HR springs.
    Diff and tranny fluids were done approx 3 years ago
    Front DF spacer done by RyanGMW
    19# injectors, miller MAF
    new cat
    stock wheels w/ 225/50/15's in decent shape
    Radiator is older but doesn't appear to be in bad shape.
    Thermostat, temp sensors and everything else are recent (in the last 2 years).
    Oil will be done before hand.
    What brakes do you guys recommend? I can likely only afford pads for the time being, but they're due for replacement.
    anything else you guys can think of? things I should look for before I go?
    I'll be sure to come back w/ video when I'm done :)
    -FW
    • 34839
    you'll want some race pads. I don't know what the hot race pads are these days though. The rest of the car sounds fine, mostly you'll want to be sure all maintenance is up to date. brakes are what will really help you keep up with those other cars, which will be tough since they have similar power/weight ratios.
    • jute91
      • Nov 2011
      • 581
      check all oil levels from diff, TC and tranny. I would even change engine oils.
      Also found on Facebook - Juuso Tero, Tampere
      https://www.facebook.com/JuusosGarage
      • furwolf
        • Sep 2009
        • 71
        Shocks and springs installed. HOLY CRAP what an improvement over the ancient stock ones. I think it just highlights my need for trailing arm and subframe bushings, though. Atleast there's no rubbing on the 225/50/15's I'm running.
        Hawk HPS brakes installed, too. I think it's time to invest in brake lines to replace my old stockers. Pedal is squishy, but better. Flush is taking place this weekend.
        Still have poly sway bar bushings to put in. CAB's are factory (not solid) but only a year or two old. Not gonna spend the money on solids yet.
        Oil temp sensor was installed as well.
        Crossing my fingers! :)
        -FW
        • Navarone
          • Jun 2014
          • 935
          Where/when is the track day? Sonoma? I've been wanting to check these out.
          • Stuffy
            • Jul 2011
            • 56
            I'd recommend front and rear strut bars. Also try a 19mm rear sway bar. If you have the time/money swap all the rubber bushing to a hardish duro poly, 75d is what I'm running and they feel amazing compared to stock. Some RTA adjustment tabs are a great improvement too.
              • 34839
              I'm sorry you went with Hawk HPS. they're not good at all for the track. :(
              • downforce22
                • Aug 2009
                • 3192
                worth saying.. when was the last time you did the timing belt?
                • Nesset
                  • Mar 2014
                  • 672
                  Yeah I would change the oil before the track day... Clean air filter,some nice gas,pads and you're off to the races!
                  -1976 2002 daily (Sold)
                  -1986 528e 5 speed daily
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5186
                    Wouldn't run the HPS if you plan to attempt to drive hard.
                    PFC 08's are supposed to be pretty good weekend track pads.
                    Originally posted by priapism
                    Originally posted by shameson
