325iX REAR Axles... Same as other e30s?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    Originally posted by ringmeister81
    Well, the clicking came back... Happens only when car is in gear, more noticeable in the lower RPM. Gets faster and less noticeable with speed. Seems to be coming from rear drivers side... I'm thinking diff, t-case, driveshaft or guibo. I can't tell and won't be able to get to a lift again until tomorrow. Stumped. I don't think it's the CV.
    Upper shock mount?
    • Nisse Järnet
      • Aug 2013
      • 1221
      Heres a pic of a 325ix axle and a 325i, its got the same flange and length but the CVs is a little bigger on the 325i.
      So i cant see a problem with replacing a ix axle with a i axle :)
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
        • Jun 2010
        • 2796
        The OD of the joints is larger, but the bolt circle is the same, right?
        • Nisse Järnet
          • Aug 2013
          • 1221
          Correct!
            • 34844
            The ix axle is probably a few lbs lighter though..
            • Nisse Järnet
              • Aug 2013
              • 1221
              Yes 1.7 lbs lighter :)
              • ringmeister81
                • Apr 2013
                • 60
                Well, I figured out the problem. Ended up being the parking brake. The loud pops were from the e-brake cable binding because it wasn't fully releasing.. I recently did the brakes, so it made sense to check.. I feel pretty stupid now, but I couldn't find the problem right away and jumped to conclusions. Thanks for all the info.. When it's time for rear axles, it's good to know that the regular 325 axles could be another option.
                  • 34844
