Testing your Transfer case without using the Jack Test
This is a sticky topic.
    • 34847
    you could use a lathe but I don't know how you would attach it or the torque wrench.
    • D.Martijn
      • Sep 2016
      • 1024
      I haven't tested the new transfer case I got for my uncles iX with a torque wrench but I did notice when doing the test on my own to feel the fluid resistance, I could not block the front axle by myself. Even with the help of someone else, it still is hard to block the axle when blocking it with their feet. Makes me think this VC is still very good.
      I'll also try and get some measurement before mounting it in the car
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • flyboyx
        • 8371
        please do. this would be a fantastic addition to this thread. I know the value you come up with will be somewhat arbitrary, but at least its a baseline between a used vc and a new one.
        Gigitty Gigitty!!!!
        • D.Martijn
          • Sep 2016
          • 1024
          Before installing it this weekend I'll put it on the bench and use the vice to block it. Although it's not a new VC, there is 66134 written on it. I'm guessing that's the milage. Since we use km here that would be 41k miles.
          Instagram
          • D.Martijn
            • Sep 2016
            • 1024
            Oke guys, I just measured the torque valvue of the VC I just put in my uncles iX.
            I started with my smaller torque wrench at 10Nm (7,3 ftlbs) which was no problem to get, I went up 10Nm each step and quickly got to 60Nm (44 ftlbs).
            I switch over to my bigger torque wrench and was able to get up to 120Nm (88 ftlbs). I couldn't go higher as that was the limit of my torque wrench.
            Here's a little video on how I tested it. I started at 60Nm up to 120Nm. (camera doesn't focus when I show it.)
            Instagram
            • The Dark Side of Will
              • Jun 2010
              • 2796
              The VC will have a spec like XXX torque at YYY RPM. The torque and speed are related.
              Alternatively, the check for one of the Chevy T-cases with a VC is to remove the front driveshaft and put a torque wrench on the front output with the trans in neutral. Put XXX torque on the output flange and if it turns 90 degrees in under ZZZ seconds, then the VC is bad.
              • notanawdix80
                • Apr 2017
                • 111
                removed
                • flyboyx
                  • 8371
                  it should not be locked. you should be able to spin the two independently of each other. if it were mine, I would take it apart to see what's going on in there.
                  Gigitty Gigitty!!!!
                    • Jun 2010
                    • 2796
                    If one output is held, the other will be stiff and only turn slowly, but it will turn.
                    If they're actually locked together, some hard part is broken inside your T-case
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4516
                      I just had a tcase that was locked just as yours is.... I was going to tear into it but scrapped it. I pulled it off of a car from someone who welded the front DS onto the car because they couldn't figure out how to remove/install it properly. It remains a mystery.
                      • notanawdix80
                        • Apr 2017
                        • 111
                        removed
                        • ndfspd67
                          • Sep 2013
                          • 111
                          Originally posted by notanawdix80
                          Broken or welded.
                          Talked to the previousprevious owner and he confirmed his mechanic welded something.
                          Yesterday i splitted the tcase to take it to the press. I will take a look later to see what is welded
                          Post pics I am curious to see what they were going for there. I also have a t-case and axle if you are in the market
                          • notanawdix80
                            • Apr 2017
                            • 111
                            removed
                            • flyboyx
                              • 8371
                              removed
                              removed
                              removed
                              this is odd.
                              Gigitty Gigitty!!!!
                                • Jun 2010
                                • 2796
                                Somebody's running for office and trying to hide his sordid past?
