Transfer case front output seal question
  • jimsbim
    • Sep 2012
    • 106
    Does anyone know if the front output shaft seal – in the transfer case, that goes to the driveshaft in the front axles, can be replaced with the transfer case in the car? Or does it need the case need to be removed?
  • spdracrm3
    • Sep 2009
    • 959
    Did it on mine in car ,and there's two seals (first is in backwards with tension spring removed,its a dust seal )just monitor depth carefully before removing old ones and wrap shaft with tape so as not to damage new seals upon install
    Sent from my SM-G360V using Tapatalk
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • spdracrm3
      • Sep 2009
      • 959
      Ive posted the pages from the factory manual showing proper install/removal on this site before ,a search might find them.
      and here you go http://www.r3vlimited.com/board/show...ght=Tcase+seal
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • jimsbim
        • Sep 2012
        • 106
        Thanks for the quick response guys. Glad I can do it in the car, any special tricks or special tool that I should know about?
        • packratbimmer
          • Dec 2009
          • 1334
          It might be a little tricky just because you do not have as much space with tools under there. Be careful not to gouge the case housing pulling the old seals.
          As far as tools go, a strong hook without a sharp tip works.
          • jimsbim
            • Sep 2012
            • 106
            Thanks, appreciate your feedback!
