shifter & transmission installation
  • Julien
    • 7471
    I'm looking to install my 5 speed transmission in my 325ix tomorrow. Can I leave the shifter out of the equation and just have the selector rod and brace in place? I'd like to do this for clearance reasons, but I'm not sure if I can sneak my hand in there and clip the lower part of the shifter in.
    thanks!
    Build Threads:
  • Kershaw
    • 11822
    You definitely have enough space to reach up and clip the shifter to the selector rod. I kept the selector rod and brace on the transmission, bolted it up, and then connected it to the shifter.
    AWD > RWD
      • 34827
      Are you talking about it with or without the transfercase attached?
      • Julien
        • 7471
        with
        Build Threads:
          • 34827
          yeah I don't think I'd want to install it later. maybe if you have tiny hands. I have giant ham fists and there's no way I could get them up there to hook up the shifter after the fact.
          I mean you can do it but it's gonna hurt..
          • packratbimmer
            • Dec 2009
            • 1329
            I always do it one section at a time trans./shifter/transfer case - easy that way.
            • Kershaw
              • 11822
              I should have said I also did it on a lift. I can't imagine I'd be able to get the angles right on jack stands. On a lift, you can put the car at the right angle so all you have to do is reach in. There wasn't tons of space, but I wasn't hurting either.
              AWD > RWD
