90 iX 5 speed manual swap
  • TheWipprSnappr
    • Jul 2015
    • 477
    Does anyone know a good link to a DIY 325ix 5 speed manual swap (stock m20b25)? Also a parts list?
    1990 325iX - sterlingsilber metallic
    1991 325i - lazurblau metallic
    Originally posted by delamaize
    E30 = Lego for men.
  • Kershaw
    • 11822
    Search for a normal e30 automatic to manual swap. The only thing you need to add extra is a manual transmission transfercase.
    AWD > RWD
    • TheWipprSnappr
      • Jul 2015
      • 477
      So I could get a 5 speed from a 325i and attach to a manual transfercase? Just making sure, i havent been into e30s for very long
      E30 = Lego for men.
      • TheWipprSnappr
        • Jul 2015
        • 477
        i mean obviously i would need other parts as well, pp, flywheel, clutch, linkage, but as far as the manual transmissions go they are all the same and will all fit the transfercase?
        E30 = Lego for men.
        • Nisse Järnet
          • Aug 2013
          • 1221
          No you need a 325ix trans or a 325ix rear housing but that's more work..
          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
          E30 M50 6 spd 764whp @ 24psi.
          E30 M20 6 spd 675whp.
            • 34839
            minus the driveshafts, they are the same on auto/manual ix's.
            and no, you definitely cannot use a RWD transmission unless you've got a spare rear case from an ix and know how to rebuild it yourself.
            • audiquattrot
              • May 2008
              • 3836
              I still regret not doing my shifter bushings when I did the swap.
              www.instagram.com/snwmble
              #snwmble
              Current:
              '05 BMW M3 - Silver Grey/Imola Red
              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
              '15 Mini Countryman - Blazing Red/Carbon Black
              Past:
              '01 Audi Allroad - Light Silver/Platinum Saber Black
              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
              '90 BMW 325i - Schwarz/Tan sport *Sold*
              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
              • Kershaw
                • 11822
                Dude, I replaced everything except the shifter carrier bushings when I did my clutch. I didn't think I had them. But I did. Not only did I have them, I had 2. 1 oem and 1 delrin set.
                That was dumb. We all do dumb things. Lol.
                Edit: also, immediately after I finished the clutch, I ordered a set of delrin bushings. Now I have 2 delrin sets.
                AWD > RWD
                • Julien
                  • 7471
                  UUC sent me a bad delrin bushing for mine. ughhhhh.
                  Build Threads:
                  • Kershaw
                    • 11822
                    Did you leave everything apart or did you just put it back together? Since it wasn't my garage, I just kept going. I'm hoping that all I'll have to do is unbolt the exhaust and driveshaft and then snake my arm up there. Haha... -_-
                    AWD > RWD
                    • TheWipprSnappr
                      • Jul 2015
                      • 477
                      is the forward output shaft the same as well or is there a manual variant?
                      E30 = Lego for men.
                      • TheWipprSnappr
                        • Jul 2015
                        • 477
                        Just so i have as much clarity as possible, i couldnt mount a manual tcase to a g260 from a 325i and then mount install the ix shaft?
                        E30 = Lego for men.
                        • CrazyPrime
                          • Jun 2014
                          • 286
                          Correct me if I'm wrong but a manual IX has 3.91 diff's and a auto has 4.10's just another thing to be aware of.
                          Sent from my E6653 using Tapatalk
                          • 101
                            • Jul 2011
                            • 764
                            That's correct. The IX manual transmission has a unique rear housing.
                            Also correct. With the small difference in ratios (3.91 > 4.10), I've seen most folks just leave the 4.10's in place. Makes the car a bit quicker off the line, but more rev's at highway speed.
                            101
                            The E30 collection:
                            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                            1987 325is - Delphin / Black Sport (son #3's)
                            1987 325i Convertible - Triple Black
                            1989 325iX Coupe - Diamondschwarz / Black Comfort
                            1990 325iX Coupe - Sterling Silver / Grey Sport
                            1981 Fiat 124 Spider 2000 - Green / Tan
                            1998 Volvo V70 GLT - White / Tan
                            1998 Volvo S70 T5 manual - White / Taupe
                            2001 Ford Windstar - Silver / Grey (parts hauler)
                            2006 Lexus GX470 - White / Tan (tow rig)
                            • TheWipprSnappr
                              • Jul 2015
                              • 477
                              how much effort/cost goes into adding the rear housing to 325i trans?
                              E30 = Lego for men.
