90 iX 5 speed manual swap
  • e30fix
    • Sep 2014
    • 311
    i would love to know this as well since im planning to do a 5 speed swap on my ix but have had zero luck sourcing a tranny
    • Ryan1642
      • Jul 2014
      • 81
      The best swap guide on the internet is here http://www.e30tech.com/forum/showthread.php?t=108141
      This is listed step by step the only difference is the extra driveshaft and transfer case. And I believe the IX driveshaft needs to be adjusted before reinstalling, it should be telescoping. Make sure you get IX specific parts when needed.
      I spend 90% of my money and women, cars, and booze. The other 10% is wasted.
        • 34827
        the driveshaft does not need adjusted. the length from the output shaft on the transfer case to the diff is the same on automatics and manuals. However, telescoping the shaft does make it easier to drop the transmission without removing the driveshaft from the diff..
        • djekels
          • Feb 2016
          • 2
          1991 E30 5Speed Swap
          My son and I are in need of swapping out a burnt out automatic transmission on a 1991 e30.
          Any ideas, links and sources we can start our research?
          • Kershaw
            • 11822
            For another automatic transmission or for a manual transmission?
            AWD > RWD
            • 2santiago
              • Aug 2015
              • 84
              What problems would I run into during the manual swap if I have airbags?
                • 34827
                No difference.
                • 2santiago
                  • Aug 2015
                  • 84
                  Sweet! So the pedal box I acquired from a manual ix will work. I'm relieved because I was reading threads on the swap and saw 'non-airbag' blah blah blah. [emoji3]
                  Thanks Nando
                    • 34827
                    Dont swap the whole pedal box. You only need to swap the pedals. Airbag auto/manual pedal boxes are the same.
                    • 2santiago
                      • Aug 2015
                      • 84
                      Oh OK. Thanks for the clarification
